I know it's hard to tell from these pics as it's not freshly mowed. I just snipped these from my house cameras remotely but gives an idea of how it cuts lower on the left blade.
I'm going to mow this afternoon so I will take a pic of a few freshly mowed lanes so you can tell easier. |
Here is a good shot of the deck showing the difference in location of the blades at the rear of the deck. A good 1/4" or more difference.
So lets say your blades are at the 12 & 6 o'clock positions in that pic. How do they look in the 3 & 9 o'clock position? Are they the same height at the tip where they are closest?
Here is a tool that use to check my decks. You will want them even on the side to side but the front should be about 1/8" lower than the rear. Make sure your blades are not bent and measure at the tip. https://www.amazon.com/Oregon-42-095...zcF9hdGY&psc=1 Here's a good vid. https://www.youtube.com/watch?v=wA9x699q4Bs
At 3 and 9 o'clock, the "drivers side" blade dipped down on the side but it was mainly lifted in the rear and pointing down to the front left. It was an odd "warp/bend". After about 45 minutes with an 8lb sledge and 3lb mallet, it's about as even as it's gonna get and I can tolerate it. I leveled it out a bit before mowing but it's not perfect yet and hopefully this weekend I can get the leveling gauge out and get it closer. I'm not near the "yard nazi" I used to be when we had a .3 acre usual residential lot here or when I lived in Texas; I'm a little more laxed about it with more area. But, I still do my best to have the greenest and most weed free yard in the neighborhood and do so without an outside company spraying. ha. I appreciate everyone's input. |
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
True. Too bad you can't just buy a pre-assembled 54" deck and add on. Even the 50". I can't see the 42" and 50" being that much different for the frame although I guess they might have a different engine than the Kohler 7000 series. I guess I'll pressure wash this 42" and get her all dolled up and sell it for a 54" of either iteration.
