Old 12-03-2023, 05:33 PM
Billy-O's Avatar
Billy-O Billy-O is offline
I don't think adding more weights beyond the beet juice filled tires and the wheel weights you already have will make much more of a difference than addressing the tires and chains(??) you are using. What have you got on there??
Plow blade
#2 Cart
QA36 snowthower
Old 12-04-2023, 11:08 PM
I have post welded on 3 brackets, which bolts to 3 of the lugs on each rear rim. I think I have 80 lbs. of Gold's Gym weights on each side of my 129 (the 10 lb. weights fit nicely in the rims.) with a sweepster broom on the front. They have always held the back down quite well. I did not see that option listed yet, so I thought I would mention it.
Old 12-09-2023, 10:17 AM
Workingstiff Workingstiff is offline
I'll put in my 2 cents, I feel there's better bite with 4-link chains. 2-link is more user friendly though.
'76 1200 Dad bought
'75 1200 "Twinsie" per my daughter
Old 07-10-2025, 06:20 PM
Cain2020's Avatar
Cain2020 Cain2020 is offline
Wink
I also like the idea of ballast, I have 9 gallons of RV in each tire on my 1872. The tires are 27X12X12 Vampires, I weighed before and after and it added close to 148lbs of weight and I notice it every steep hill and every time I use the 1300LB roller.
Tags
1450, quietline, rear weight box, suitcase weight
