Old 02-09-2024, 08:41 AM
That's something I'll look in to also Jsoluna, thanks.
The only reason I was looking at the Surplus Center hydraulic hoses is because they are $11 each. Way overkill for what's needed but friendly on the wallet.
Old 02-10-2024, 06:07 AM
jsoluna's Avatar
jsoluna jsoluna is offline
Yeah, that's an amazing price for hydraulic hose. You can barely buy the two hose ends for that price. A local hose crimping shop here would charge 55.00/each for that.
http://www.solunagarage.com
Old 02-11-2024, 12:54 AM
Steve N Mi Steve N Mi is offline
Oak why do you think it is an oil line leaking? Do you see fresh oil running from the hose clamped line? You know better than I where the leak is (you beinng on location) but I had a similar problem with an 1872 and I was sure that I had a leak at the fitting close to the engine. After power washing the crud away from the area I could see oil drip/splash on the tin below the fittings. The fittings were tightened but the leak continued. Turns out it was the oil pressure sending for the red light that was leaking at the gasket between the bakeolite and metal fitting. It would sparattically let oil drip to the line fittings and then to the tin below. I still feel a little foolish about all the time spent chasing that leak down. I only admit to it here in case it will be helpful to others. Steve
Old 02-11-2024, 10:27 AM
Steve, I'm not sure it is a hose leaking but the po cut the crimp off and installed 2 hose clamps. I have not seen this engine run in years but it looks like it was leaking at one time.
Old 09-21-2025, 04:57 PM
Ian181 Ian181 is offline
Did anyone ever come up with a good solution for replacing these lines? My niece's 1862 leaks some at the lines going to the oil filter, they're tight but they still seep. The engine side doesn't seem to be leaking, yet!
