Old 05-14-2024, 09:18 PM
IHCub1450 IHCub1450 is offline
Wow some confusion here apparently.
A ball bearing is an assembly consisting of an inner race,------- the part that slides on the on the crankshaft, ----- and an outer race that slides in the engine block or bearing plate that bolts to the block.
Also the balls between the inner race and the outer race are kept in place by a race retainer, it all is manufactured as an assembly, inner and outer race, balls and ball retainer.
End of story.
Ball bearings are not like a Timken style, tapered roller bearing, that consists of a cup and a cone with the rollers attached to the cone.
A ball bearing comes as an assembly.
Now there are some exceptions that I'll not go into as its irrelevant in this case.
Hope this clears up any confusion.
Yes, thank you, that clears up a lot of confusion and helps a lot.
1976 IH Cub Cadet 1450
2006 Cub Cadet GT-3200
