Old 06-17-2024, 05:43 PM
garydee's Avatar
garydee garydee is offline
Default Repairing plastic side panel pins tricks/tips?
Here is yet another option for a side panel pin replacement...
I threaded the hole in the side panel with a 5/16" tap. Then I used a plastic bushing with an aluminum screw. I drilled a hole in the side of it so I could use a hairpin to secure the panel when installed on the tractor.
Simple fix...
Old 06-18-2024, 10:27 AM
1811woody's Avatar
Looks good should outlast the rest of the tractor.
Old 06-18-2024, 10:31 AM
Rex B Rex B is offline
Simple fix...
I like that. I'd probably add the epoxy. Where do you get aluminum screws?
Old 06-18-2024, 10:53 AM
garydee's Avatar
I have never had the screws loosen up, but epoxy or thread lock would be good insurance...
The screws came from my Dad's collection of hardware that I inherited. Not sure where you could get them now. I like them because they won't rust, are easy to cut and drill and do the job using what I have. Maybe a 5/16" oval head brass screw would be more readily available to replace the pins. Bushings should be an easy find in any hardware store or in your junk drawer.
