Old 08-31-2024, 04:18 PM
KK560 KK560 is offline
Filter make & part #
Not sure. It doesn't say. I'm thinking it's a Baldwin.
'65 100 w/ creeper, '68 125, '75 1000, '76 1250 w/ hydraulic lift and 3pt, '77 "2550", '78 1200 w/ rear pto and spring assist lift, '79 1250, several mowing decks, 42" snow blower, 42" dozer blade, Brinly plow, 5' Massey disk, and New Idea dump cart
Old 08-31-2024, 05:36 PM
The spirol pins (what should be installed there, and not split roll pins) may look good and still be visible on either or even both sides of the coupler but still be broken internally, with one or both ends you may be able to see still stuck in the coupler.
I suggest you hold the coupler tight w/pliers and and try to spin the driveshaft while doing so with another pair of pliers or vise grips.
I have seen this issue before an 882 diesel which are hard on pins.
Both ends still in the coupler but the hydro input shaft not turning.
And when driving the old pin out, what's left of it comes out in pieces.
It may be tough lining up the coupler with the hole in the driveshaft when installing a new spirol pin, use a short length of 1/4" bolt shank to line the holes up and drive the new pin in while pushing the piece of bolt out the other side.
Good luck!
NOTE TO SELF: replace the pins in the 882 BEFORE heading to Bluneirs plow day in October!!
I did that and they seemed fine, so I took it back out and ran it without the cover and didn't notice it slipping any, but I did notice it whines a bit more in reverse than it does forward. It also didn't act up at all this time.
Is it just me, or do things always work fine whenever you're trying to diagnose a problem?
Old 08-31-2024, 08:30 PM
Go back and read post 9
if it is not working well at higher speeds it sounds like the suction side is impeded, and that can be caused by a restricted filter or suction line or a lot of moisture and you are foaming the oil, causing cavitation.
The filter is easy to change and inexpensive ( less than a burger meal at Mickey Dees) you will not have to drain any oil and will loose very little in the filter.
Then you have eliminated that problem.
I guarantee a filter will last longer than a meal going through your digestive system.
Old 08-31-2024, 08:32 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Since you don't see anything obvious, I agree with doing a filter AND oil change no matter what at this point.
For the correct filter: https://www.onlycubcadets.net/forum/showthread.php?t=12
Plow blade
#2 Cart
QA36 snowthower
Old 08-31-2024, 10:49 PM
Then you will have eliminated that problem. Preach it George.
Ken
Old 09-01-2024, 11:55 AM
Is the freewheel lever on the right side engaged? Stuck release valve?
Old 09-19-2024, 08:52 PM
I drained the oil, cleaned out the sludge, changed the filter, and refilled it. Didn't seem as responsive as usual, but also didn't have any problems. Thanks for the advice!
Old 09-19-2024, 11:03 PM
Ambush Ambush is offline
It’s always a good idea to cut your old filter apart and inspect the element for metal. Especially if you suspect a hydro problem or have an unusual noise coming from the unit. Free diagnostics.
