Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 12-03-2024, 01:14 PM
West Valley G West Valley G is online now
Retorquing the heads on these K series engines is pretty much
a standard maintenance item for me. Have never bought one
without blown a blown head gasket. I am a bit anal but usually
torque them every year as an up keep item. Every time, I find that
they have loosened some. Even after many years of use. Have not
blown a gasket since.
Never dawned on me either to just drill a hole in the shroud. Duh.
I'm a bit slow sometimes.
Ken
Old 12-03-2024, 03:39 PM
Graflex45's Avatar
Graflex45 Graflex45 is offline
Originally Posted by ironman View Post
While it's apart, you can bore a hole in the shroud right above the bolt heads for a socket to go thru.
I don't know that it causes any great cooling issues but if it bothers you plug the holes with these....
oh that's a great idea
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller
70- 38in deck, 42 inch deck
Old 12-03-2024, 06:13 PM
Graflex45's Avatar
Looking at it actually it seems they thought of that, or it's a happy little accident if you loosen the bolts on the sides of the top sheet metal and take off the lift bracket the head cover will slip off
