Pulling the power from the hour meter worked for me on my 1541. I only had to hold the switch in run for a couple of seconds before starting.
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
Personally, I would use a 5 pin automotive relay wired like this.
A wire from the starter solenoid goes to pin 87A which provides power to the fuel pump through pin 30 when the key is in the Start position. A wire to from a lead that is hot when the key is in the Run position goes to pin 86. When the key is released to the Run position, the relay is energized, pins 87A and 30 open, pins 87 and 30 close and power is maintained to the pump. If you want the option run the carb "dry" you could add a toggle switch to pin 87. |
I like Ironman's idea of using a relay for the pump accessory. This way, you won't be overloading the "run" circuit (i.e. red/white wire). If this was my project, I will do it.
Still.... the more I think about this even though I think adding a diode (directional) or use Ironman's relay, something still doesn't come clean for me with why the starting circuit fails with the pump running on the run circuit. Now I wonder..... maybe bad ground! With a bad ground back to battery, the electrical circuit can do strange things to find a way to complete a circuit, including passing thru pto relays and other safety circuits, thus triggering a no start condition. Try running a jumper from pump ground to battery negative and see what happens.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
The common problem with these tractors is the solenoid engagement power runs through the ignition switch. This overload the internal contacts. My 2084 with a fully charged battery will not crank until I hook a 10-amp charger, then it fires right off. The solution is the relay that everyone recommends. I need to do this, just haven't gotten around to it.
If I were adding an electric fuel pump (be sure it's a low-pressure version) I'd run power through an identical relay. Just buy two kits. |
FOR ANYONE INTERESTED...
Relays are available from an ebay seller named skyline-autoparts. He has them on sale 5 for $9.86 (only 10 lots left). Free shipping too!! I bought these and was amazed that they came with a plug in socket and mounting tab. I don't know how he can sell a quantity of 5 for only $9.86 with free shipping? Get them while you can!!! ![]() Here are the specs: 5Pcs 12V DC 40A 5Pin Car Relay Switch Harness Socket Waterproof Automotive SPDT skyline-autoparts (502) 98.9% positiveSeller's other itemsSeller's other itemsContact seller US $9.86 or Best Offer Was US $10.95 (10% off)Price details Condition: NewNew Sale ends in: 21h 36m Quantity: 1 10 available23 sold |
I'll be fixing my solenoid issues with these. So far I'm good with the vacuum pumps. But I do have an issue with my 2084 draining the battery overnight. I suspect my HF winch has a low draw when off. Between that and the solenoid draw I have to hook up a 10A charger to bump it off. |
Glad to help you snag a great deal on some things you needed!
I have 5 of those relays on order, thanks for the tip Gary.
Are these the same relays that are used for the Starter Assist?
Cannon |
Yes they are...I have them on all three of my cubs to overcome any safety circuitry deficiencies that I may or may not have. Fun project! Cubs start every time...nice!!
Get some before they are gone. You can't beat 5 relays with sockets shipped free to you for only ten bucks!
