You could sand the plates flat but I bet that would take forever.
Are you sure the rear pin on the coupler wasn't broken? Does the driveshaft turn when you release the clutch?
Was the coupler at the end of driveshaft properly pinned to the input shaft of the transmission? It looks like there's some galling and the coupler was just free spinning on the input shaft.
And the bolt used to pin the coupler to driveshaft is not recommended. Spirol pins are recommended for the coupler to driveshaft and input shaft.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Looks like the stub shaft on the tranny is broken off. Time for some transmission work, remove, repair, replace reinstall...
When I got it, no it was not bolted. My guess is that it was bolted at one time and twisted/broke it right off. |
Darkminion_17 very likely made the correct call that input shaft is toasted. It looked like it to me but I wasn't so sure. It sure does look messed up and short (broken off).
regarding the drive shaft, what would be a good replacement for the collar that has the bolt in it? Or is the one I have fine( replacing the bolt with a new spring coil pin of course)
I would take a good look at the inside of the coupler with the
bolt in it. As strange as the tranny output looks I would think that coupler is toast. You can click on the cub parts lookup at the top of the home page here and get a part #for the coupler and then go elsewhere to buy the part if it is bad. I have a 124 sitting on the bench and output shaft of the tranny measures around .83 from the seal. From the outer edge of the shaft to center of pin hole is about .25 if that helps. As far as sanding the pressure plates. I have done that just to clean them up but as said it would take forever to true them up that way. Unless they are warped you are probably ok on that. Ken |
This is your problem part, called reduction drive.
#24 on the drawing, p/n 717-3073. You will probably need 18, 19, & 20 also. The coupler and drive shaft can be gotten from Parts By Jeff at the top of the page. |
In the midst of replacing the input shaft on my 126 I have discovered that the needle bearing(PN 941-0362) is no longer serviceable. Does anyone know a source for one that isn’t for Cub Cadet? Because they want $99 for it.
Used, on eBay....from sponser up above....
https://www.ebay.com/itm/27683715891...Bk9SR77N64ScZQ bearing is ball, not needle. |
