Very low odds I will ever show my machine to anyone who knows any better. I like my dash decal and am definitely not ruining the logo
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller 70- 38in deck, 42 inch deck |
I had one that was mounted here by the PO. Put a 2" hole in this spot.
Ok, just got the new meter yesterday and did a short ride and my electrical problem seems to have been fixed by taking the generator apart and sanding the new brushes so they contact the commutator across the whole face of them and cleaning the regulator contacts. Have to mow today and see if the regulator voltage setting works like it did on my test bench.
Meter shows around 15 A charging when I momentarily ground the field connection so everything seems functional and the generator is not getting immediately hot. I just put in an order for a replacement wire harness though because the wires are cracking where they come out of the loom to go to the generator and ignition, that old insulation has very little life left in it.
I've had several over the last 40 years that someone mounted a volt or amp meter on the rh side of the dash just like you did.. many years I thought it was a factory option.. I've never actually had one that had the factory bracket in the knee slice location! LOL.. looks good where you put it!
Jay 40 years of Using and playing with IH Cub Cadets! Proud owner of the following: Cub Farmall, Super A Farmall, Original, (2)70's, 72, 100, 102, 123, 105, 125, 127, 108, 128, 1450, (3)782's, Yellow 982, 1782, "Sam's" 2182, M Farmall and a #7 trailer |
I saw a video of a 102 a while back that had the ammeter mounted directly on the starter generator. It's out of the way if you don't mind looking around the side of the tractor to check. But I suspect the vibration would make it illegible...
