Old 06-02-2025, 05:10 PM
EternalArianne EternalArianne is offline
Originally Posted by dale c. View Post
set the timing with a timing light . s mark on flywheel mark it with paint or something visible adjust point gap to correct timing . clean or replace points first
I have seen that online where people say adjusting the timing to 18 instead of 20 fixes it the rattle. I'll look into it
Old 06-03-2025, 01:17 AM
Billy-O's Avatar
Billy-O Billy-O is offline
Check for loose grass screen on the flywheel....
Plow blade
#2 Cart
QA36 snowthower
Old 06-03-2025, 09:09 AM
Snake oil I say!
Old 06-03-2025, 08:27 PM
ironman's Avatar
ironman ironman is offline
My 149 makes so many friggin' noises that I gave up worryn' about them.
But that was 15 years ago. Still starts & runs fine, and does the job.
Sometimes searchin' for the devil brings more agony than bliss.
Old 06-22-2025, 05:56 PM
I checked the point gap and it was correct at .020 but the contacts were severely worn and concave. I replaced the points and condenser since the seller provided a new set. Engine still sounds the same. It's somewhere between a knock and a rattle, almost like something inside is loose/wobbling. She definitely needs a rebuild as I suspect this is all original from 1966.
Side note, now the carb is leaking. I replaced the bowl gasket and it was fine for a while, now it's leaking out the throat which means the float is stuck. Gimme a break...
Old 06-22-2025, 10:42 PM
So clean the crud from under the needle seat and it will stop leaking.
Old 06-22-2025, 11:14 PM
Improper cam shims, to loose.
Spec is .005"-.010" for 240,301, 321 & 341
Old 06-25-2025, 02:58 PM
Grandpa53 Grandpa53 is offline
If you've ever been around an old Harley you would've heard the same noise. Solid valve lifters are a major contributor to the "KOHLER RATTLE". More noticable at idle/low rpm.
Old 06-27-2025, 12:25 AM
It does seem to smooth out at higher RPM
