Old 10-02-2025, 11:45 AM
TheLoneRanger TheLoneRanger is offline
When I had one of my 149's engine rebuilt, I also had the balance gears removed since several advised me they are ticking time bombs. Little more shake and rattle, but not bad at all. Good ear and attention to detail. Glad to see your 149 is getting the attention it needed.
The previous owner had already removed the balance gears when they “rebuilt” the engine. At first when I heard the balance gears were not reinstalled during assembly I thought that was a bad thing. After doing some research, and seeing what condition the old ones were in, I realized that it was the right thing to do. It's interesting to me that these gears are a common failure point.
It's definitely a good thing that these were not reinstalled
Old 10-03-2025, 07:05 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Yikes! those look awful. The bearings in the gears and the studs they ride on wear which, more often then not, causes catastrophic engine failure.
Queen Of The Quietlines!
Old 10-21-2025, 10:40 PM
Block, Piston, Crankshaft, & Connecting Rod back from the Machine Shop
Got the Block and Crankshaft back from their respective machine shops and they look great. If anyone in the Houston area (specifically SE Houston) is looking for a machine shop, let me know and I’ll send you their information.
Engine Assembly. Two steps forward, one step back
While the Block and Crank were away, I read the Kohler Engine service manual and knew one of the first things I wanted to do was install the camshaft and check the end play. So that’s exactly what I did when I got the block back. Spec per the manual was .005” - .010”. Unfortunately, even with the .005” shim installed, the end play was in between .014” - .015”. Looks like I need to order a camshaft shim
