Old 01-06-2026, 09:42 PM
CubDieselFan's Avatar
Some nasty stuff in there.
Old 01-07-2026, 10:51 AM
SDBOB SDBOB is offline
I thought about those drainback holes. I am afraid of breaking the bolts as CC rep said. However my plan as soon as reenforcement get here is to run tractor around get everything good and warm,hot. Then remove the bolts. Figuring aluminum expands and helping with breaking bolts loose without breaking them. Anyone have any other ideas to prevent breakage? Thanks Bob. I will get pics. Also should I buy new bolts,and what strength?
Old 01-07-2026, 05:37 PM
I am pretty sure one of the sponsors makes a reinforcement bracket for the SGT transaxles. the bolts have a tendency to loosen up and leak steel bolts in an aluminum case if I recall.
Old 01-07-2026, 07:34 PM
Yes that's the brackets that are on the way to me.
Old 01-07-2026, 09:27 PM
You will not snap a steel bolt off in an aluminum hole. But if you're not careful with the wrench you will strip the threads in the aluminum on re assembly.....ask me how I know
Old 01-08-2026, 10:25 AM
I wouldn't want to do that!!!!!!!!!!! Yikes.
Old 01-08-2026, 11:26 AM
Bob drilling the drain back holes is an easy mod, just pull the axle tubes and drill a 3/8" hole or holes depending on the style main case that you have. Some have a little hump at the bottom so I drill a hole on each side those without the hump I just drill 1 hole. Just try to get the hole as close to the bottom as you can. See attached pics.
Old 01-08-2026, 01:12 PM
Thank you. That helps alot knowing different designs. Have you any advice on ways to make sure I dont break bolts? CC rep told me bolts can break. I was thinking of buying new bolts 'unless' the bolt threads are unique to cc aluminum casting.
Old 01-08-2026, 05:33 PM
If you are putting the rear brace kit on that Sam designed and everybody and their brother sells now you need to check and see if the seller included new bolts. You need to lay your existing bolts out and add the thickness of the braces to your new bolt length. You will also need to use some Permatex #2 on the bolts that go into the rear case if they are open to the case.
Here is a brace kit I installed on one of my 982's with the rear hitch.
Old 01-08-2026, 05:58 PM
Just got braces in mail. Mine has the bolts included. Paint them first.Now get tractor apart. Thanks guys.
