Closed Thread
Old 07-20-2026, 11:18 AM
skydog skydog is offline
Originally Posted by Graflex45 View Post
Take the deck belt between the spindles off, then check if the spindle assemblies are securely attaches with all the belts and if the spindle has any up and down or side to side movement. easier to check without the horizontal tension of the deck belt.
If you rotate the spindle slow or quickly do you feel any tight positions or unevenness from a bad surface on the bearing or bearing race.
Take off the blades and check the centering of the blade and the balance of the blade, unbalanced blades will cause the deck to rumble and vibrate.
check the tensioner pully and see if its bearing is smooth and the tensioning mechanism is free to move.
Thank you, I’ll check all that out!
Old 07-20-2026, 11:53 AM
Mower issue turned out to be blade related. When I removed them to sharpen them, evidently i didn’t align the star flange correctly with the blade. It still tightened down but allowed some chatter. It allowed a slight bit of movement causing the noise. This winter I’ll replace both spindles as the star flange got a little boogered up.
Old 07-21-2026, 12:57 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Originally Posted by skydog View Post
You were being a smart ass and got called out on it. Admit it.
Admit nothing , you gave a very poor and basic description with no information relating to model etc then got all wound up about a suggestion
End of conversation
Old 07-21-2026, 10:10 AM
CubDieselFan's Avatar
Alright guys, lets agree to disagree. He figured out his issue, time to end this one.
Closed Thread
