Old 10-05-2010, 10:00 PM
cadetfarmer cadetfarmer is offline
Cool Surging
Big Nasty;
If you figure out that surging problem let me in on the cure. I've got an 18hp twin cyl. Briggs with a similar problem, I got disgusted last year and shoved under a tree and gave it the finger and havn't looked at it since. Except to notice that it has the same size tires as my 102 whick needs some.
I never drove a B model Mack, I did drive an L200 International semi tractor at one of my Jobs when I was really young, had a steering whell about 3' across and couldn't turn it around on 100 acres.
Cadet Farmer
Old 10-05-2010, 10:50 PM
T-Mo's Avatar
T-Mo T-Mo is offline
I haven't been around a Speedex, and what I'm about to say is just second hand knowledge, but I hear they're a bear to work on - very complicated, even more so than a Cub Cadet and a John Deere. I'm not sure I would want one anyhow. Now a Power King or an Economy or Jim Dandy........
Old 10-05-2010, 11:55 PM
I've owned two Speedex tractors. IMHO, they don't compare to a Cub Cadet.
Old 10-06-2010, 07:15 AM
Default Please Tell Me
Wild Bill;
By larger rear tires do you mean, wider, or taller.
You are giving me ideas.
Cadet Farmer
Old 10-06-2010, 07:19 AM
T-Mo's Avatar
Speedex (getting off-topic)
http://www.speedex.com/
http://www.speedextractorinformation.com/
I heard some of the Speedex, depending on transmission, you had to shut off the engine and move the belt to a different pulley groove to obtain a different gear speed. On others, with the Peerless transmission, you didn't have to do that.
Old 10-06-2010, 07:50 AM
Terry, you had to do that, with the two Speedex tractors, I used to own.
Old 10-06-2010, 07:02 PM
Question Tire size
Nickvanorman;
So what size are the rear tires on your Speedex tractor?
Cadet Farmer
Old 10-06-2010, 10:39 PM
cadetfarmer, the rear tires on the Speedex tractors I owned, were 7-16 and 8-16.
Old 10-07-2010, 07:10 AM
Default Thanks
If this idea works out, I will be posting some very usefull information.
If I understand this correctly, the taller tires on a speedex gives it more traction.
Sooo if a Cub Cadet had taller tires, it should then get better traction?
Hmmmm!
Gotta try something, someone told me once.
If anyone has any input on this idea, I would be glad to hear it.
Cadet Farmer
Old 10-07-2010, 07:19 AM
bsyphrit's Avatar
bsyphrit bsyphrit is offline
as i learned from building a truck motor once once you build on part bigger you expose the weakness in other areas, put in bigger motor and tranny lasted i week replaced that and rear end lasted 8 months.
point is if you increase traction there will be a point that another part could fail. just somthing to consider before you jump in to a project.
