Old 10-15-2010, 07:23 PM
Thanks guys. I checked both the pulleys and belt.....no problem at all. The belt is like new and since others stated that theirs squeals for just a second as they are shifted into 2nd or 3rd, then I'm no longer concerned that something is being stressed. It is just a brief squeal and the tension seems to be tight enough. I appreciate all of the input.....
Old 10-15-2010, 07:27 PM
Sminkey
Guest
Posts: n/a
Default ya!!
Sweet O', looks awesome with dual ags, only thing I can think of to top it off would be a set of dual fenders:biggrin2.gif:
Old 10-15-2010, 07:53 PM
nickvanorman
Guest
Posts: n/a
a 7hp motor shouldn't have trouble turning 12" dual ag tires. its your belts you might want to take a look at. i know on the speedex (8hp briggs) which is belt driven, it can run duals on 16" rims and it wont squeal if you keep the tension on. on my cub though if you put it under heavy load it just breaks the tires loose or the motor goes under load since its all shaft drive.
