Old 10-23-2010, 05:48 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Nick,
It was locked up when we bought thr tractor.Great thing to deal with as we got the tractor alot cheaper. I parted another 1250 out that was mechanically good,but severely beat up by the PO. They just welded everything when it broke.Hood,tierod ends deck, etc and the motor and clutch as well as trans still worked well with no smoking.I was planning to use this on my grand sons red and white tractor,but we gotta do something to keep the snow plowing back in business..I have plenty of time to locate a motor for the other tractor.
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 10-24-2010, 08:19 AM
bignastyGS's Avatar
Poor boy has no heart now...
Some pics of the troublesome pieces...
JB Weld should be able to fix this back up huh??
Maybe some slight polishing with emery cloth to knock off the roughness....:biggrin2.gif:
not sure if a little oxy/acet will cure this...
If all goes well,I will be reinstalling a 12 hp later today and maybe have it running today or sometime this week. All depends on how much better I feel with this flu crud..
Pat Harmon
Loganton,Pa
128 Cub Cadet
LT 1042 Cub Cadet
1200 Cub Cadet
1941 John Deere H
Old 10-24-2010, 09:43 AM
WOW
She really let loose.
Old 10-24-2010, 11:13 AM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
I don't understand why the 3 pin driver broke.
Sorry to hear of your misfortune Pat.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 10-24-2010, 11:51 AM
Merk Merk is offline
Was the motor apart before it was installed in your Cub?
Was your Cub still using iso mounts?
Old 10-24-2010, 02:53 PM
cubs-n-bxrs's Avatar
I would have to say the motor was either ran out of oil or the rod was installed backwards. That will smoke a rod every time. And as far as the driver plate that looks like an alignment issue.
Old 10-24-2010, 04:55 PM
bignastyGS's Avatar
I checked the oil which was just changed a week or two ago and it was in the grid as well clean.I had used the tractor all summer and even mowed with it as well 3-4 weeks ago. I don't know why the driver broke but maybe when rod let loose,it did it then. All my ISO mounts are new and I maintain this tractor possibly too much.Like I said earlier,this motor was in pieces so we threw it back together and it lasted way longer than we expected. I now have the 12 hp in the frame and swapped the tin and am in the process of bolting the mounts and small items. Then I will remove the clutch to install the 3 pin driver.
Pat Harmon
Loganton,Pa
128 Cub Cadet
LT 1042 Cub Cadet
1200 Cub Cadet
1941 John Deere H
Old 10-27-2010, 07:31 PM
bignastyGS's Avatar
OK update time again. I retrieved he 12 HP motor which again we don't know the total history about and swapped parts from the 14 HP onto this motor. oil is full and I tried to get it running to see it's condition before spending too much money. After I sat it in the frame,I swapped carbs and wired it up. I hooked up the fuel tank and gave it a go. It had all kinds of spark but the gas was spewing out the carb. In no way did it fire. After reading Matt G's timing and going back out,still no go. I was stumped. So,tonight,I came home and removed the carb again.I was going to swap the 12 carb on and for some reason,I decided to hit the key.Then immediately seen my trouble. The intake valve was stuck open. Took the head off and sure enough,it was up. I seen a piece of carbon stuck on the valve face. I rotated the flywheel and managed to get the piece out as well as the other carbon off the piston and valves. I then spun it over and the valves operate great now. Looked in the cylinder and it looked nice with no scoring. I reinstalled the head and assembled it. First turn and it started right up. It is definitely a smoker now.I plan to change oil and maybe add a little marvel oil in it to see if it clears up. It has tons of power and runs really smooth.Just need to see if the smokingwould clear. This motor was rolled around and the muffler might have some oil in it as well. Time will tell I guess..
Pat Harmon
Loganton,Pa
128 Cub Cadet
LT 1042 Cub Cadet
1200 Cub Cadet
1941 John Deere H
Old 10-27-2010, 09:31 PM
Glad to hear you got the 12 horse running
Old 10-27-2010, 09:56 PM
Glad you got it going, Pat. Hope the smoking problem clears up.
