Old 12-01-2010, 06:54 PM
TEET's Avatar
TEET TEET is offline
Here we go again...the never ending Hy-Tran debate.......
Gary, I'll ship you some...send me a pm
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 12-01-2010, 07:02 PM
gcbailey's Avatar
gcbailey gcbailey is offline
Matt - you gotta remember where I'm at... po-dank WV. The only farms around here are beef and dairy and that's far and few between due to the excessive milk distribution from a slanted cow on a hillside.... I even called a local semi service center, they carry KW and Volvo, but the only Hydraulic fluid they stock is Rotella.
I've read more than enough that I'm gonna stick with the Hy-Tran. I closed the site, but I read about a 3 page article from a retired AF Col. who was a service commander and he did extensive comparions of Hy-Tran vs. numerous products for 20+ years.
Gary
Old 12-01-2010, 07:13 PM
TEET's Avatar
Gary,
Do any of these Independent Cub dealers have any? I'm sure you looked into these already...but
COUNTRY POWER EQUIPMENT, LLC
1235 MERCER STREET
PRINCETON WV 24740
Phone: (304) 425-8273
7.9 miles
Directions
MOUNTAINEER POWER EQUIPMENT
ROUTE 2 BOX 311
PETERSTOWN WV 24963
Phone: (304) 753-9775
12.6 miles
Directions
FOWLKES MACHINE CO INC
200 CASSELL ROAD
WYTHEVILLE VA 24382
Phone: (276) 228-2513
View Cub Cadet Dealer Site
27.1 miles
Directions
BECKLEY FEED & HARDWARE CO
405 PRINCE STREET
BECKLEY WV 25801
Phone: (304) 253-3389
33.1 miles
Directions
POWER ZONE-ALL SEASONS
1250 ROANOKE STREET
CHRISTIANSBURG VA 24073
Phone: (540) 260-0061
34.7 miles
Directions
SPECIALIZED SAW & MOWER INC
3954 WEST MAIN STREET
SALEM VA 24153
Phone: (540) 380-3901
45.9 miles
Directions
TWIN COUNTY SAW & MOWER
1869 MEADOW STREET
GALAX VA 24333
Phone: (276) 236-3922
47.6 miles
Directions
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 12-01-2010, 07:17 PM
My 4 work tractors get used on average about 10 hours per year. I think the minimum Hytran-change window is 100 hours (The Sundstrand service manual claims you can go ~400 hours (or something like that) with a filter in the system in some situations). That means at the current rate my tractors will go at least 10 if not more years without a Hytran change. The ones that are not operated during the winter sit in an unheated, partially un-sheltered barn. There's plenty of opportunity for condensation to form inside the rearend. I don't want that rusting anything. And nothing will rust so long as there is Hytran in the rear. This would be even more critical if my tractors had to sit outside. I have had a couple of tractors that I drained WATER out of, yet had no rust whatsoever anywhere inside. I can't be so sure. One time I bought some of the off-brand stuff, and I put some in a dish and some Hytran in another dish. I put some water in both. The Hytran dish formed sticky globs, and the Off-brand dish did nothing. The water and fluid stayed separate. I have also had a couple of other tractors that had less hydro whine after draining out fluid of questionable origin and replacing it with Hytran.
Just because they both meet the same specs doesn't mean they are the same. 5 gallons will take care of 2 tractors with some left over for ~200 hours each if you want to sit in the middle of the change interval... That's like 19 cents per hour of the tractor's operation. That's still pretty cheap in my opinion
Old 12-01-2010, 07:30 PM
steve59's Avatar
steve59 steve59 is offline
Hy-Tran is a lot more pricey than the other stuff. That's all my Dad and I've used on our IH and Case IH stuff for more than 40 years. Take your own container to a Case/IH dealer. They carry it in bulk and will give you a better deal. I'm an AMSOIL dealer too but will only use HY-TRAN in our equipment.
Old 12-01-2010, 08:32 PM
gcbailey's Avatar
Jeff, Country Power is my local dealer... that's the one the post refers to. I honestly don't expect to see them around too much longer. This is also the same outfit that said there was no such thing as a "Cub Cadet" and that the "Original" is the model name...
Mountaineer in Peterstown doesn't carry it, only Rotella there too... The others I haven't tried.
Gary
Old 12-01-2010, 08:40 PM
TEET's Avatar
If you dont have any luck with the others, let me know, I'd be happy to figure out a way to get some to you. My local dealer stocks quarts, and bulk...I owe ya
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 12-01-2010, 08:41 PM
steve59's Avatar
Use this link to find a Case IH dealer in your area and take a couple clean 1 gallon jugs for a great deal on HY-Tran.
http://www.caseih.com/northamerica/P...erLocator.aspx
Old 12-02-2010, 06:20 AM
gcbailey's Avatar
I'm gonna call this company this morning. It's about 45 minutes away, not too bad. They came up on that search.
200 CASSELL ROAD
WYTHEVILLE VA 24382
Gary
Old 12-02-2010, 06:43 AM
TEET's Avatar
200 CASSELL ROAD
WYTHEVILLE VA 24382
They are also the 3rd on the list I posted for ya
I read about them on a STIHL forum a while back as well, they sound like a decent place to deal with.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
