You haven't seen anyone use larger wheels because they'll hit the fenders, and then you probably wouldn't be able to get more than a 38" deck on there. Not to mention they don't make lawn & garden or lug tires for 13" rims.
The problem with the bearing is that a plain ball bearing is not designed for thrust loads, just radial loads only. I don't know how long it will last with the stronger clutch spring...probably not long. One possible solution might be to bolt a brace with a pillow block bearing in the frame behind the clutch spring like the pullers do; that will take up some of the thrust load and should help the bearing last longer. The largest deck you can use is a 50". |
