Old 12-29-2010, 06:52 PM
MrGitrdone41's Avatar
I put the weights on the hitch but it is connected the the frame not the trany but is on the draft plate with grade 8 bolts. It works great and didn't cost a penny.:biggrin2.gif:
Old 12-29-2010, 07:43 PM
jwk49 jwk49 is offline
Default weight
Thanks for the advice, I will check it out this weekend, I never gave it a thought, it will give me a new project for the new year
Old 12-30-2010, 01:25 PM
What i did was i got a 4x4 and cut it to about 3 sinder blocks. Then i drilled holes in the wood to put a bolt thew so they don't come off then u want to mark were to drill the hole to connect the wood to the hitch, Then get two long bolts. Use the one to connect the wood to the hitch and the other to put in the holes u drilled. mount the wood on the hitch then put on the weight. Than put the bolt in the hole and then ur done! It is very simple to make.
