Old 03-10-2011, 09:26 AM
IAfarmer's Avatar
IAfarmer IAfarmer is offline
I recieved the kit, and overall, the gaskets look great. You are right Matt, I would rather reuse old head gaskets that put those cheapies in....not that i will.
AJ-Thanks for the stud number. I was hoping someone had a less expensive alternative. I may check our local oddities shop, as they tend to have any type of nut, bolt, tool, bearing, etc a guy might need.
We decided to clean up the engine sheet metal rather than paint it. I took rubbing compound to the metal and WOW! it really cleaned up well. Other than scratches, and some yellow overspray from the PO, it looks perfect. I plan on spraying new black on the top of the engine to set it off perfectly.
Hopefully we start reassembly this weekend.
Thanks for all the help.
Old 03-10-2011, 09:43 AM
Just to help:
Here are the head gaskets that I have been using for the past two seasons with no problems
They are Stens on evilpay #190456782563
You must retorque them of they WILL fail,- BTDT
Old 03-10-2011, 01:15 PM
Just to help:
If they actually look like they do in the picture, you will notice the gasket has the fire ring around the cylinder part of the gasket. That is what you want too see. Most of the other aftermarket gaskets don't have that ring and that is why they fail so fast. Good find George.
Old 03-10-2011, 02:47 PM
Yep mine came as pictured,
I can't believe others make a sandwich style head gasket that is not crimped around the center or fire ring.
Old days a composition gasket has one side steel and the other side copper,and the” meat” was asbestos.
