Old 01-20-2011, 07:06 PM
Originally Posted by pete240 View Post
I checked the charging system using the "operational test" that Roland linked to, and it was showing a max of 13.8v at WOT. I let the battery sit for a couple days and it reads 12.6v, so I'm think I should go through and clean all the contacts? Could the cold weather really just be the culprit? The high temps are pretty much below freezing most days. If i switch to 10w30, will i really notice a difference in ease of starting?
If you are using 30 weight, you will see the difference,---- is it Day and night? no
But it is easier on the engine when it is cold as it lubes better/quicker.
Try a test yourself, pour some 30w in a small cup, out of a qt. container and observe the flow,-- like honey @ cold temps.
Pour it back in the container and try the same thing with 10W30 you will see a difference.
We really are not talking a large amount of oil when changing oil on a small engine.
and above all, never rev any engine when it is cold as you are just asking for early wear/ or worse
