Old 01-18-2011, 09:13 PM
Roanoker494 Roanoker494 is offline
Originally Posted by william1041200 View Post
looks as if the screen comes off last on a k -181. in your pics there are no screws holding the screen to the flywheel.
Thank you for that info. Once I got the bushing out I removed the large nut then the aluminum hub and screen came out together, no screws holding the screen itself.
Johnnie Watkins
All original Model 800, what else could I want?
"Thought I was wrong about something along about three years ago, but as it turns out I was only slightly mistaken."
Old 01-18-2011, 09:24 PM
And the story comes together. Looks like one of the many pieces of metal got caught between the cam lobe and tappet.
Johnnie Watkins
Old 01-18-2011, 10:22 PM
I suggest putting the large nut back on when you start to remove the flywheel. That thing can fly off and land right on your toes, ask me I know . It will pop pretty loud when it breaks free.
Old 01-18-2011, 10:41 PM
Actually it didn't pop at all. I bolted on the puller, tightened the draw bolt down about a quarter turn past hand tight and tapped the flywheel once. That is what you get when the engine was stored in a temperature controlled garage for the last 35 years, no "rust welding" going on here.
Johnnie Watkins
Old 01-18-2011, 11:15 PM
william1041200's Avatar
Default keep nut on...
thats sound advise. I luckily never had one launch.
Your engine has a story written in about 1-2 seconds...
Old 01-18-2011, 11:21 PM
Default youre great with a camera
you need to replace that entire governor shaft . There should be a 'flag' welded onto the end of the shaft that runs through the case to the throttle control governor linkage. The 'flag' is what the governor gear's weights push against that resist high rpms without load.
Old 01-18-2011, 11:25 PM
Rhoderman's Avatar
Rhoderman Rhoderman is offline
Incredible pictures! You're lucky in that when she broke, she quit running pretty much right there. No scoring of the cylinder wall. Lucky.
I got the one that didn't let loose, and somebody ran the snot of my engine. I was able to rebuild it without too much trouble though. About the only difference is you have to find a camshaft for yours.
Check those big ball bearings for the crankshaft - if they ingested some bits-n-pieces during the post "ah, crap" spin down, they might need replaced as well.
Jim in Lafayette, CO
Cub Cadet 122, 126
Old 01-19-2011, 12:03 AM
That is exactly why we NEVER re-use a plastic governor. Also check the teeth on the crank shaft, you don't want any chips or other damage there either.
Old 01-19-2011, 03:43 AM
I found the "flag" in the oil pan and I half suspect it is what caused the broken cam, or it may have been a pin out of the governor gear.
Johnnie Watkins
Old 01-19-2011, 03:48 AM
I have found new bearings for $15 each, so I am going to replace them either way. The bearing on the output side seemed a little "sticky" feeling, I don't want to risk another tear down.
Johnnie Watkins
