Old 02-04-2011, 01:29 PM
From a picture posted on another forum (will post if that's ok...I can't remember which one I got if from)
Stock: .5 x 1.5 x 26"
Casting end: 7/8" thru hole .75" from end to center of hole
Rockshaft end: 1/2" thru hole with 5/8" counterbore, 0.150" deep, 1/2" from end to center of hole.
The parts lookup supports this, as the bar attaches to the rockshaft with a 1/2" clevis pin. My 782D lift bar has a counterbored 1/2" hole for the clevis pin. With a 3/4" hole, nothing's keeping the clevis pin in there, and if there is no counterbore, you won't be able to get the pin in far enough. There is almost no clearance between the lift bar and the frame rail, hence the counterbored hole...
The picture Roland posted is for a NF. That bar isn't the same.
Old 02-04-2011, 01:58 PM
Tractor2nv's Avatar
Tractor2nv Tractor2nv is offline
Default Lift Bar Bushing
In the drawing part#5 is 3/4" O.D. and inside is 1/2". Made out of stainless in pic is done by a friend of mine,work great on NF,WF and speads for us.
Fool me once shame on you,fool me twice...shame on me!
Old 02-04-2011, 04:59 PM
Here's another idea...once you pick which measurements you'd like to use, make one out of a piece of scrap wood first and make sure you get the proper range of motion. It's now clear that nobody's measurements and data seem to be completely correct, which doesn't really surprise me. I've asked on this forum and a couple others for people to measure stuff for me before, and not once have they turned out to be correct.
Old 02-04-2011, 06:24 PM
Well, looks like there are a couple of versions of this Lift bar.
Old 02-04-2011, 09:28 PM
The scrap wood idea sounds pretty good. Just fab up a mock bar and then drill and or countersink to correct pin measurements. The sleeve hitch should be level when in full down mode?
Old 02-04-2011, 10:02 PM
juniors1282's Avatar
The one I have from a 782 is like the one Matt discribed. Could there be a difference form IH built tractors to CCC built tractors, just a thought. Mine is from an IH built 782, and is counterbored. I know your 782d is CCC built but is the 3 point original to the tractor, or could it be from an earlier tractor. Like I said just a thought!
1966 IH cub cadet 102x2
Old 02-04-2011, 10:03 PM
I don't know where it should be when all the way down, but the first concern that popped into my head was the pin in the cast piece putting a nasty dent in the fenders when the lift is all the way up if the bar is too long. That is what will happen if you use a WF lift bar on an 82 series tractor.
Old 02-04-2011, 10:16 PM
I think the last two comments are for me. The 3 point I am using is currently on my 128 that I pulled from a QL last summer. I know the WF lift bar won't work, that is why I was trying to get measurements so my buddy with a machine shop could fab me one up. I figured if anyone knew if the U shaped hitch is supposed to be level when in full downward position I could get a measurement from rockshaft to the top cast lift for the distance of the holes. I am almost positive what Matt is describing is what I need as far as a counter sink hole for the rockshaft pin to sit flush in when installed.
