Old 04-02-2011, 07:59 PM
Originally Posted by Mooner View Post
Merk, how should it be set up for using my Brinly plow or rototiller? Float lock pin in place? I'm not going to use my 149 for mowing. I use the 1000 for that.
Wondering the same thing myself about my 782.
Old 04-02-2011, 08:21 PM
Merk Merk is offline
by Mooner
by _DX3_
The tiller has a chain between the Cub and the tiller....no solid link.
On a sleeve hitch system there is a slot in the lift arms on the sleeve hitch and I think there is a slot on a 3 point lift. There is not a need to have down pressure to run a tiller and the plow was design to have some float built into it. I wouldn't run a solid lift arms when plowing. You need some float built into the set up for hills and valleys.
All my sleeve hitch setups have slotted arms. If your moldboard plow is set right you won't need any down pressure.
Old 04-02-2011, 08:28 PM
Mooner's Avatar
Mooner Mooner is offline
Wow, there sure is a lot to learn with these things! I've had my 1000 for 9 years and just mowed and towed things with it. I love it. But this 149, now it's a different beast...lots of fun and tinkering. Wahooo!
Thanks, Merk!
