Old 04-24-2011, 03:34 PM
jpianalto jpianalto is offline
I finally finished my rebuild Friday! Mowed the lawn and it seems to work well! I will have some carb adjustments to make as I had to half choke it part of the time...
I ended up having to basically destroying the pto pulley to remove it from the tractor. A local shop has a 129 in their bone yard where I can get a few parts. I took his entire pto pulley, flywheel and all. In removing my pulley, I ate up the flywheel basket in a couple of spots. After not being able to get the bering off, I decided to get everything put back together to see if the 129 pulley would work on my 147. They are a bit different. It works great so far!
I still want to replace the flywheel if I can get the colar off. The set screws are also eaten up on it as well. I'll have to do some creative removal skills o. It. We shall see...
Tags
pto belt deck 147 clutch
