Old 05-03-2016, 07:54 PM
Default What did you do to your Cub today?
Since we have a thread about what you did with your cub today I thought I'd start a thread about what you did to your cub today.
I worked on getting the engine mounted in the 1282 and when I got home my son wanted to play outside so while he ran around I spent some time polishing the 108 and 1211 so they look top notch for plow day Saturday.
Pap's 100
Restored 108
1211 Dual Stick
1050
Old 05-03-2016, 08:53 PM
longislandcubs longislandcubs is offline
I had some time this morning so I pulled a troublesome ignition out of my 149 and ordered a replacement from one of our sponsors.
Old 05-03-2016, 09:44 PM
john hall's Avatar
Changed oil and sharpened the blades on my 2072. Also greased it, changed air filter and gauged the tires. Tightned the alum block on the side of the engine where the lines for the remote filter hook up--hopefully this is was the cause of my oil leak.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 05-03-2016, 09:51 PM
Terry C's Avatar
Terry C Terry C is offline
Put new coil,condenser,points,and plug wire on the 100.
Took the non-IH exaust pipe off the 982 and prepped the orgional
pipes and shields for paint.
Took the plow off the 782 cause it was taking up too much room.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-03-2016, 10:21 PM
I changed a front light on the 1512,
Though it would be a bright idea!
Up to 534 and counting...
Old 05-04-2016, 12:37 AM
bocephus1991's Avatar
I walked by them in the garage, hauled off an old water softener! Lol
Brian
Old 05-04-2016, 06:32 AM
I got my new original running.
Old 07-05-2016, 08:17 PM
Working on new mower deck wheels. Bearing exploded on one of them.
Old 07-05-2016, 09:23 PM
mike.beccue mike.beccue is offline
Ran some fuel lines and installed some gauges. Waiting on radiator and fan to finish diesel install. Next new hydraulic system
Old 07-05-2016, 09:57 PM
Dirty Steve's Avatar
Interesting flying tractor you got on the ceiling there..... what is the engine?
