Old 11-20-2010, 10:22 PM
Sminkey
Guest
Posts: n/a
Default Nice Allen & squatch!!
Nice to see all the cub action I've been loggin in some hours this week on my cubs. Pulled the creeper off my 2nd O' and figured out why it's popping out of gear, fixed that. Decided to take the reduction housing/clutch from my 1st O' and put that on my 2nd O'. Got it all back together and took it for a test run, works good:biggrin2.gif:. I'll save the creeper for when I restore the 2nd O'. Had to weld up some cracks in the frame too
Old 11-20-2010, 10:23 PM
Great job, Jude!
Old 11-21-2010, 08:24 AM
Looking good ACecil
Both pictures are cool but the first one is my favorite :biggrin2.gif:
Old 11-21-2010, 11:48 AM
Thanks Diz! I like that one also. You can see the Fall color in the background.
Old 11-21-2010, 12:49 PM
juniors1282's Avatar
Nice picture's Allen looks like fun!
Good work Squatch, Love the colors on your super, cab looks great.
You've been very busy Sminkey, Looking good can't wait to see that plow in action.
1966 IH cub cadet 102x2
Old 11-21-2010, 01:58 PM
IHinIN IHinIN is offline
Nice work guys. Looks like you've all been busy.
Yesterday, I rewired my 126 since the wiring was a mess when I got it. I tried starting it but the battery didn't have enough charge in it to get the engine to start. It did fire a couple times but that was it. Tomorrow, I'll try the battery out of my 100 and see if it'll start then. Hopefully, I can charge up the battery and not have to buy another one.
Old 11-21-2010, 06:14 PM
weaverama weaverama is offline
Default Running real good
Well I got the 682 out to mulch leaves on the neighbors yard with my son. My boys earn $50 bucks a shot at cutting grass for the neighbors and they wanted the yard cleared of leaves too. (3.0 acres) My son was on the JD 345 and I was on the 682; he followed right behind me. I had the deck pulled up high to mulch and he came through with a cut and finish mulch. We knocked the leaves down real quick, it was good to watch 13 year old learn the tricks of leaf management
The 682 started to backfire at the end but I managed to finish. Thinking it was a lean condition I sprayed a little carb cleaner on the carb mounting base. She perked right up when I sprayed so I thought I had the problem nailed. I pulled the carb to check the gasket, oddly it was a loose choke cable that caused the choke to not open all the way making it run rich. WHATEVER. She's back together now and running way too good for the $200 I spent to buy her. I love this tractor!!!!!!!!!!!
Weaverama
Old 11-21-2010, 10:31 PM
Thanks Junior & Adam!
Old 11-23-2010, 12:55 AM
Sminkey
Guest
Posts: n/a
Default Got my parts from ccspecialties!!
Got home from a very long day at work and sitting on my doorstep was my parts:biggrin2.gif:. I just spent the last 4 hours working on the cubs, mainly the 71. I rebuilt the pto and installed that, got the bronze pto button too. Hooked up the rod then reinstalled the blower that has a new wear edge and 14t sprocket! Replaced the retainer rings on my O's creeper and now it works perfectly. Will try to get the rest done tomorrow to see how the blower runs, hopefully well
Old 11-23-2010, 01:33 AM
That blower looks awesome Jude! Your taking great care of your fleet! Thanks for the updates!
