Old 11-28-2010, 06:56 PM
nickvanorman
Guest
Posts: n/a
well...motor blew up in the 122 tonight. it was getting really weak and the connecting rod just went tonight. so, i found a K301as replacement. still sucks tho!
Old 11-29-2010, 09:30 PM
ihnick's Avatar
ihnick ihnick is offline
Well tore into the 128 motor last week. There was a terrible whine noise and here the crank bearing was pitted and sloppy. Then found out the balance gears were ready to fall off then the ring gaps were rejected. So se that motor aside and pulled apart a 122 motor and that needed to be bored too. So now I got a 129 motor that needs a rod that will probably go in. Man o man why can't I get a cub that doesn't need engine work
Nick.
Old 12-02-2010, 07:17 PM
IHinIN IHinIN is offline
I fixed the leaking carb on my 126. No matter how I set the float it would leak gas like the float wasn't closing of the flow of gas. I found out that the bowl vent hole was plugged up. I cleaned it out and now it doesn't leak. (fingers crossed) I'm not sure how the vent being plugged caused the carb to overfill but I'm glad it's fixed. Now I can get the 126 running and tune the carb.
Old 12-03-2010, 12:07 AM
Great job, Adam!
Old 12-03-2010, 05:10 PM
Hauled some leaves with the 100 and cart. Had to get a pic myself.
Old 12-03-2010, 05:18 PM
Great pic Allen! Looks odd without you sitting on it tho.
Old 12-03-2010, 05:21 PM
Sminkey
Guest
Posts: n/a
Default Nice Allen!
I can see from the pic your 100 is still running:biggrin2.gif:. I'm gonna have to set one of my tractors up with the dullies, I like it alot!!!
Old 12-03-2010, 05:23 PM
Thanks guys! It was great getting some seat time today!
Old 12-03-2010, 06:48 PM
juniors1282's Avatar
Lucky you Allen, No seat time here, not enough snow to plow, and to cold to play.
1966 IH cub cadet 102x2
Old 12-03-2010, 08:52 PM
Sminkey
Guest
Posts: n/a
No snow here in the valley yet. We're supposed to get snow showers the next 5 days so maybe hopefully I can plow at least:biggrin2.gif:. Tonight I simple greened the hood and fenders on the 124 and to my amazement the hood looks sweet! Had a bunch of algae/fungus growing on it, had to scrub it hard to get it off. Started tearing down the rear of it too.
