Old 10-06-2016, 10:56 PM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
Looks great! It was quite the project...lots of time and money. Thanks for sharing throughout this process.
Queen Of The Quietlines!
Old 10-06-2016, 11:04 PM
DieselDoctor's Avatar
Looks great Steve! These supers are fantastic tractors. Sure glad you found mine for me!
Old 10-07-2016, 11:49 AM
Your super is looking sharp, Steve!
Old 10-07-2016, 01:02 PM
Terry C's Avatar
Terry C Terry C is offline
Your plastic looks better than mine
I say put the decals on and put it to work !
She's looking good to me
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-11-2016, 12:24 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Looks Great Steve!!
Put the decals on and put her to work!!
Jay
Proud owner of the following:
Old 04-23-2017, 11:38 PM
wthompson01 wthompson01 is offline
Sam. I can understand the $$$$$. I just spent a young fortune building a 48" deck for my 2166. New everything, including the bolted in baffle. Basically taking a deck shell and making it into a running mower. And it was worth it. Every penny.
Old 08-02-2017, 12:27 PM
rudedawg's Avatar
rudedawg rudedawg is offline
I just stumbled across your post. I also have a 2166 w/42" deck purchased new in 2003 that just hit 700 hrs. The Kohler 16 hp. single cyl. is now acting like it is starving for fuel after running for an hour or so. I can choke it and it runs smooths out then starts sputtering, take it off choke and it smooths out for a little while then does it again. I have just replaced the fuel line from tank to pump, fuel filter, spark plug, cleaned gas cap & added some Seafoam but it still does it. Also my deck will not cut level anymore. I have new blades and have checked the blade tips side to side to each other and there is just a tad of deviation but should not be enough to cause the extreme uneven cutting. I used a deck gauge and everything is level until I actually mow and it looks like patooy. I have adjusted the front lift arm to achieve a half way decent cut and it is crazy how much one side it lifted higher than the other. I also lowered the deck on the discharge side by adjusting the nut until it's almost bottomed out and the tires are at correct psi. It's 14 years old and I have maintained it religiously but I am at my wits end and would appreciate any advice before I just give up on it. Thanks, Rudy.
Old 07-01-2021, 12:26 PM
cruizer2182's Avatar
cruizer2182 cruizer2182 is offline
Thumbs up
I just came across your thread as I was looking for threads with a couple of issues I'm having with my 2182 (wiring and not starting). I read your entire thread and was so impressed and inspired by your hard work, dedication and passion. in my opinion your 2182 is the best, badass and beautiful SGT on the planet. Your post has hit my inspiration button into overdrive to do something with my machine. After it gets the immediate wiring issues taken care! lol. Anyway I just wanted to say thank you for sharing with us, helping us and inspiring us. You should be very proud
Old 07-01-2021, 12:44 PM
Check to see if your lift arms are still parallel.
Old 03-14-2023, 06:14 PM
Cadetpuller Cadetpuller is offline
Originally Posted by Dirty Steve View Post
When I bought it our temps were in the teens. Had to drag it on and off the trailer. I feared the rear end was either slugged full of water and froze or potentially damaged. After sneaking it into the corner of the family farm shop ( I do not work on the farm) I was able to warm it up. Once the fuel issue was solved with temporary fuel tank. I drove it around. No power steering but moved well under it's own power. The rear dip stick reported nothing but frothy pink milk. So I pulled the rear cover knowing full well I would be drilling Sam's return holes soon. Strawberry milk anyone?
Where is the write up for "Sams return holes and vent" I'm getting ready to pull mine and want to do the same.
2182, 1050 spread frame puller
