Old 06-02-2012, 10:33 PM
I like the hood yeller
Up to 534 and counting...
Old 06-03-2012, 01:44 AM
Duke
Where is the Powder coater located? I have some crusty wheels for a Deere 317 I’d like to get done.
I sent you a link.
Duke, those parts really look good. I don't know what I'd do if I got to work on a Cub that wasn't all greasy! Have you got the hardware back from plating yet, so that you can start screwing this back together?
That really looks nice. Can't wait to see it as it goes together. Did you have to do much bodywork on the hood and fenders?
Congrats!
John
Thanks John! The tins on this one are in real good shape so no body work needed. I do have parts at the body shop that should be done this upcoming week.
No grease is a good thing!
Shines like a new penny almost time for assembly
Thanks Todd!
Looking top notch, buddy!
Thanks Buddy!
I figured you like that!
Old 06-03-2012, 01:46 AM
methos we just got a 1962 original and it had bad rear end oil in it so we changed the oil but under the left rear axel housing there is a big hole and it is weeping oil do all of them have it its all original because you know about originals its not threaded it appears just to be a round hole is it supposed to have that hole
Your axle tube is leaking at the o-ring. You can replace that and stop the leaking. That hole is factory. Not sure if I know everything about them but I'm learning!
Old 06-03-2012, 07:24 AM
Default cub cadet original
methos how do i replace the o ring is it a seal or something
Old 06-03-2012, 09:48 AM
Page 22
http://ccmanuals.info/pdf/O%20Chassi...e%20Manual.pdf
You'll have to pull off the axle tube and rear cover and remove the 3 bolts to remove the seal. Replace seal and reassemble. This is the short version.
Old 06-03-2012, 10:29 AM
Wow! Those parts look awesome. Can't wait to see you doing some assembly work.....you'll be Those O's will look good.
Old 06-03-2012, 10:41 AM
mrcubcadet's Avatar
....That looks GREAT!!
-105___ Tiller
Old 06-03-2012, 06:10 PM
Thanks Todd! I'm ready to get these done but still got some waiting to do.
Thanks Conner!
Old 06-03-2012, 06:52 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default White parts
Duke, are you planning on making those tractors all yellow, or was this just a trial run with the hood?
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-03-2012, 07:59 PM
John
It was a mix up at the powder coaters. Everything will be the correct colors when it's done.
