Old 06-26-2020, 05:40 PM
IHinIN IHinIN is offline
Finished the reflectors today. Adjusted the carb, set max RPM and checked timing with my timing light. Drove around the yard a while and let it run to break in the engine. Picked up some white paint for the hood and a battery to replace the one I stole from the 129.
File Type: jpg BE482A66-CE6A-4DDA-89A2-18D1FC63F6B2.jpg (37.6 KB, 150 views)
Old 06-27-2020, 02:53 AM
Looking good, Adam!
Old 06-28-2020, 06:08 PM
Thanks Allen.
Found out that the tractor was only charging at 12.5 volts so I tried unsuccessfully to adjust the output of the voltage regulator. It would either charge at 12.5V or the contacts would stick and charge at 17V. I pulled an old Delco regulator out of my stash and swapped it onto the tractor. It was also charging around 12.5V so I messed with the adjustment screw on the voltage regulator coil and got it charging at 13.6-14v.
Old 08-23-2020, 04:50 PM
Third time’s the charm with paint on the hood. The first time, there were several wavy spots that showed up in the gloss. Several coats of primer and lots of block sanding later it was ready for another attempt. The second time, I didn’t thin the paint enough and it didn’t flow out so it wasn’t smooth. As I tried to sand it smooth this morning, I cut through the paint in a couple spots, so I sprayed it once again.
File Type: jpg E876685F-A312-43D6-8B6E-C1B6A54B40C3.jpg (19.2 KB, 111 views)
File Type: jpg EDEBB00D-3DAB-41CE-AB26-6CD8A0D30531.jpg (24.0 KB, 109 views)
Old 08-24-2020, 09:46 PM
I’d say that the paint is plenty good for a tractor. Check out those reflections. I can read the air cleaner decal in the paint.
File Type: jpg B061B089-4DC0-49E0-827E-9AB38B71D85D.jpg (15.2 KB, 92 views)
File Type: jpg 8777C75E-CF98-45A5-BEAF-97C4C2429118.jpg (15.4 KB, 92 views)
Old 08-24-2020, 10:23 PM
IHCubCadet147's Avatar
Looks great!
Old 08-24-2020, 10:35 PM
mortten mortten is offline
I’d say also. Nice.
Doug
Dad's 122 w/42" cast deck, spring assist, lights,weights, rear lift
1250 w/hydraulic lift, lights,weights, spring assist.
50C deck converted to an A with front wheels
44C deck converted to an A with front wheels.
QA-36A
42" blade
Old 08-25-2020, 05:42 AM
Paint and tractor look awesome Adam.
Old 08-25-2020, 06:38 AM
Looks Great Adam.
Old 08-25-2020, 09:18 AM
mrjeep81's Avatar
mrjeep81 mrjeep81 is offline
Exclamation
“Good enough for a tractor”!?
Looks better than most cars bought today!
1450SGT
1641
528 SWE Snowblower,
