Old 03-05-2011, 08:33 PM
aagitch's Avatar
aagitch aagitch is offline
I managed to finish the deck today. I just have to put the casters and wheels back on and sharpen the blades.
Old 03-05-2011, 09:36 PM
Sminkey
Guest
Posts: n/a
Originally Posted by mrcubcadet View Post
Brought home a Cub Cadet 1650. Cleaned it up a little bit, and ran it.
[QUOTE=mharrison;61216]Finally got my headlights today and got them installed on the 100. next i need to replace the grill.
Nice 1650
The 100 is coming along nicely mharrison!!
Adrian, you're doing some fine paint work there
Good stuff MrGitrdone41!
I got the pto off the 124's engine, also pulled bearing, collar and flywheel pulley. As you can see the pulley is pretty toasted, will be sourcing a new one But it's nice to get all that stuff off finally!
Also took the thrower and front end off the 71 to fix loose flywheel pulley, and Lew was right. The crankshaft key was toast, so I'm in the middle of replacing that and threadlock the set screws, have to get ready for the snow, calling for 8-12" here tomorrow night into monday morn
Old 03-05-2011, 10:18 PM
I noticed that your S/G bracket mounting on the 124 is in a different hole,should be mounted to the one above it.That is defiantly not the same motor that it came with when new.Does that motor have a deep sump oil pan?
Nice looking deck Adrian.
I like when a cub is a turn key operation...
Up to 534 and counting...
Old 03-05-2011, 10:37 PM
nickvanorman
Guest
Posts: n/a
just bought another Haban Sickle bar. this ones a Haban 402E instead of the 402D. complete. gonna mount it to the 102.....or buy a wideframe. i want a 149 i decided today. haha
Old 03-05-2011, 11:40 PM
william1041200's Avatar
I got a wideframe and need a sickle bar ! Wink Wink!!!
Old 03-05-2011, 11:45 PM
nickvanorman
Guest
Posts: n/a
i want a 149 soooooo bad. the guy i am getting the sickle bar from has one...but he wants $2200 for it....FIRM....no thanks. haha
Old 03-05-2011, 11:56 PM
Fine job on your deck, Adrian!
Old 03-06-2011, 02:59 PM
mrcubcadet's Avatar
Today I got the lights on the 1650 going just need to get a new switch.
And, I got looking at the drive shaft to see that it has been rubbing a support brace on the frame...
-105___ Tiller
Old 03-06-2011, 08:46 PM
Sminkey
Guest
Posts: n/a
Nope, it's a replacement k301as, and I have the original replacement manuals for it and the 124, qa42, and mower deck! They came with the tractor. I think it has a deep sump oil pan, how do I know for sure??
Old 03-07-2011, 01:23 PM
MrGitrdone41's Avatar
Sam, are those 8.50 Tru Powers on your cub? I really like the looks of them.
Yes they are Allen. They get good grip.
1988 1812,dual ports
1973 108
1968 125
