Old 03-16-2011, 10:41 PM
Awesome job on your adapter, Ben!
Old 03-17-2011, 12:23 AM
hilltop's Avatar
hilltop hilltop is offline
Great stuff guys!
Bruce, nothing like getting "muck stuck" to make things interesting! Glad the wife could come get you unstuck . . .
DX3 - Nice looking paint . . . I'm getting ready to paint my 42" deck - I'm thinking I'll just ship it to you
Buck - Duke's right, get your wiring problem moved over into the problem solving forum where it'll get noticed and Roland or one of the other guys will get you fixed up toot-sweet. Welcome to OCC!
Old 03-17-2011, 12:17 PM
Iowa Farmboy Iowa Farmboy is offline
Took the 451 blower off the 2072 last night only to fin that when i removed the drive belt the front PTO has the bearing going out of it. Now I'm not sure what to do as I use the front PTO for two things. Running the 451 and a 60" haban deck. So I'm at the cross roads do I put in the newer 6" PTO so that I spin my blower at the proper speed, which is cheaper than the OEM one. Or do I spend the money to keep it OEM and still spin the blower slower, which works but not as good. I guess I just dont know if I put the larger one on would I need to change the pulleys on the Haban deck? Or would spinning it faster do a better job with out harming my deck?
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 03-17-2011, 03:14 PM
krisb krisb is offline
Spent the morning out working on the yard in this beautiful spring weather.
I had a old red wishing well sitting in my front yard that was falling apart and dry rotted. I used the blade on the 1811 to push over the well, then brake it into pieces. Once that was done I used fast straps and attatched them to the pieces and the tractor and drug them back to my burn pile.
One of the reasons it was all rotted was at some point someone had filled it with dirt. I used the blade to smooth out the dirt and the real wheels to compact it down. Turned out quite nicely.
I love getting to play with my tractor.
Old 03-17-2011, 04:56 PM
aagitch's Avatar
aagitch aagitch is offline
I would just replace the bearing. It's only about 10 bucks from the local bearing shops.
Old 03-17-2011, 04:59 PM
aagitch's Avatar
Was getting ready to load the trailer for the plow day on Saturday and the neighbor came over and asked if I would plow his garden. It turned out pretty good considering I've done nothing more than set it up per the manual.
Old 03-17-2011, 05:43 PM
Great pics, Kris & Adrian!
Old 03-17-2011, 06:42 PM
Sminkey
Guest
Posts: n/a
Default Nice Pics Guy's!!
It hit 56 degrees here today. Got the cubs out of the shop and cleaned house. The 147 wasn't running to well, backfiring through the carb, so I did the static timing (Matt G.'s) and it was way off. Took me a while to get it dialed in right, but finally did. Went to start it up and nothing I finally figured out it had no gas in it. Filled it up and got ready to start it and low n behold gas was pouring out of the carb. Just rebuilt carb and has been fine since rebuild(couple week's ago). After taking it apart for the 3rd time I figured out it was the brass float, took it off and shook it, was filled with gas. Stole the float off a k161 and now she's good to go!! Also threw the 6.5's on the 71 and I like the look. Video to come shortly of 147 & rear blade
Old 03-17-2011, 08:01 PM
ihnick's Avatar
ihnick ihnick is offline
looking good jude. i'm gunna have to put my rear blade on also and fix my driveway pretty soon. i just realized you might need a bigger shop pretty soon lol
Nick.
Old 03-17-2011, 08:09 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Default Movin Gravel
Got two loads of gravel today. Started moving it around my mud hole of a yard. Lots more to go ,but this is what I got done so far.
Had plenty of supervisors (wife & kids) until I told them they could use a hand rake to help.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
