Old 03-19-2011, 09:32 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
Thanks for the pics, guys!
Hey, how about a few pics of your day of plowing?
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 03-19-2011, 09:42 PM
Well since I couldn't go plow today, I have been needing to redo my fuel tank for the 128. I have grown sorely tired of sanding, LOL.
I went to Ace Hardware and picked up a quart of Zip-Strip paint stripper. WOW!! Why hadn't I been exposed to this stuff before, LOL.
It took the tank down to bare metal FAST. I then put a very nice coat of primer on it. Will lay some paint on it later on.
I also decided to take the tunnel cover down to bare metal too and covered in primer. The hood and front cast grille will be next, then will do the tower.
Will the fiberglass dash hold up to the stripper? Thought I should ask before I found out the hard way.
Old 03-20-2011, 02:32 AM
william1041200's Avatar
I finally got the motor stripped and out of the 124 today! What a horrible dirty dirty job that was!! Worst part was getting that 40 year old manual pto off the darned thing. Lets just say that the only undestroyed part is the crankshaft! Im pretty sure I made use of all known 4 letter words at least 20 x each, have new wounds, and now I am pretty happy. So glad that the weather is warming up around here!
Old 03-20-2011, 07:20 AM
nikster's Avatar
nikster nikster is offline
Default Warmer weather & got the itch,
Back down to the high 40's yesterday, but last weekend we had mid-60's+.
Just a pleasure to start tinkering outside. Cleaned up the muffler real good & gonna paint with some high-heat BLACK.
Oooops, no paint?
New primer & paint for the light panel, rewired, new bolts, new decal.
Gotta have lights for my # 109. Don't need them but I think they are cool.
Old 03-20-2011, 09:52 AM
Awesome job, Nik!
Old 03-20-2011, 10:32 AM
Great pics and storys on what you all have been up to. The past couple of days I've been busy getting ready for plow day. Evan and I was getting some seat time Friday and the 100 died and after 3 condensers and coils 2 new autolite 216 plugs 2 spark plug wires I think that the switch is bad. No spark so going to check that out today. I found out that the ag's on the 100 are mounted on the rims the wrong direction causing me not to be able to use them on the the 125 or 1200. So got to fix that as well. Friday Evan pulled the 100 to the house with the 125. I was being cute and lowered the bucket down and lifted the front tires off the ground. Well when it quit running I hooked a chain to the bucket and Evan pulled it closer to the house for me. 125 can pull! No wheel weight turf tires no tire spin just pulling the 100 with the bucket on the ground.
Got the spring assist on the 1200 loaded it on the trailer for the plow day. The rods started knocking so slept on it and at 5:30am I unloaded the 1200 and loaded the 125 on to take to the plow day. Front turf tires and all. That was a good choice! I will go into detail on the redneck plow day thread.
Had a blast plowing and got lots of seat time in! Thank you Vince the redneck plow day was great!
Old 03-20-2011, 02:54 PM
vbob01 vbob01 is offline
Finally went and picked up some supplys, undercoated the bottom of my fender pan for the 2550. Need to get it back together and start on the 1250.
Bob.
2550 with sleeve hitch
1250 with tiller, blade, deck
826 snowblower
Past machines 72,1650
Old 03-20-2011, 07:24 PM
MrGitrdone41's Avatar
I got a plow and a disc of the 128 and plowed up a garden. It so much fun I'm plowing the guy across the the road a garden tommrow. I'll have pics up soon my camera died.
1988 1812,dual ports
1973 108
1968 125
Old 03-20-2011, 08:32 PM
mrcubcadet's Avatar
Today a friend and I got the drivetrain and motor back in the 105. Getting oil for the motor and hydro, and a hydro filter and then I'll try to start it.
-105___ Tiller
Old 03-20-2011, 09:06 PM
cub123's Avatar
cub123 cub123 is offline
fired up the 106 today,i just put in a K-301 from a 127,anyways,as i was starting i saw that it was blowing a mist out around the spark plug,upon further inspection i found that the head has a crack it it,so just a quick question,will my K-241 head work on it?
