#21
I found some links for you.
http://www.xtrememotorworks.com/Cub%...50-4%204x4.htm http://www.mytractorforum.com/showthread.php?t=107934 |
#22
WOW, I think I am starting to get Articulated 4x4 envy... That thing is sweeeet!!!
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
#23
Ok so I got a little bored tonight so here's some more links for ya to follow. Not going to do any more searching tonight for them so so if you want more type cub cadet articulated into google and enjoy the results!
Most of the planning work is done for you. http://www.ihcubcadet.com/forum/mess...tml?1110235917 And here we have Artie (this is the one I rembered seeing a while back) http://www.cubcadetman.com/content/i...ects&Itemid=55 |
#24
I've been toying with the same idea of a 4x4 Cub. Guess it would be more accurate to call it a tractor with mechanical front wheel assist, but either way all four would be powered. It would look just like Dan's 100 with the Dana front end & operate the same way for the most part, but use a GM rear axle and no transfer case. Here's the math that I have thus far & what parts I would like to use. Dan's 100 is chain driven off the pinion shaft in the tranny thru a couple of gear sets then to the front pumpkin. My tractor is a 100, so I stayed with the stock tire sizes or 23" dia. in the back & 16" dia. up front. I carried all of my numbers to 4 decimal places for accuracy & ease.
Tires & Rear Axle: 23" dia. = 72.257" cir. --> @ 3 MPH = 43.8435 RPM 16" dia. = 50.265" cir. --> @ 3 MPH = 63.0259 RPM Stock gear drive diff = 13t & 46t ---> 3.5384 : 1 ratio Rear pinion speed = 43.8435 RPM x 3.5384 = 155.1358 RPM Using a GM S-10 Blazer rear axle with a 3.42 ratio for the front axle would give you: 63.0259 RPM x 3.42 = 215.5485 RPM @ the pinion input The ratio difference in the two input speeds: 215.5485/155.1358 = 1.3894 : 1 This ratio difference would leave you with a drive option (sprocket or gear) of an 18 tooth item & a 25 tooth item. The math check shows that 18 x 1.3894 = 25.0092, but if you convert it over to a percentage of difference between the real world parts & the equation would give you: 25/25.0092 = 0.9996 --> 1 - 0.9996 = 0.0004% A difference of four tenths of a percent is almost certainly negligible in our situations & the slop in the drive system overall is much more than that if I had to guess. This setup would give you the addition of one gearset to drive system (the tranny countershaft to the front prop shaft) to which you could drive the front axle without the need for a transfer case like Dan's tractor has. The S-10 Blazer axle with that ratio is fairly common (up here in MN at least) because that's the gears they put in the pig when the Blazer had an auto tranny. An added benefit is that the S-10 wheel bolt pattern is the same as the bolt pattern on the rear of the 5-lug Cubs. Would like take power from the tranny like Dan did on his 100, and tweak the rest of the system a bit.
Mike - Ramsey, MN '65 100 - #126432 Options: V61's, 8.5" Tru-Powers, stock sleeve hitch, Xtreme sleeve hitch adapter Attachments: Dad's 42" Dozer Blade & 38" 3-spindle deck, 42U deck, Homemade Sleeve Hitch Dethatcher & a QA36A Snowthrower Mods: K301 Upgrade, IHinIN's clutch pivot upgrade, SST driveshaft, custom bar axles "Why buy something shiny & new when you can save something old." |
#25
Looks like you've put a lot of thought into this. Just so you know, the bolt patterns aren't the same. The S10 is 5 on 4.75" and the Cub is 5 on 4.50".
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
#26
Measure a couple of tires to be sure, but I'm willing to bet that a 23" tire isn't actually 23" in diameter. Same for the 16" tire. I think I would figure out what you'll be using for tires first, and then measure the actual diameter, which will vary by tire style, manufacturer, etc. I can find at least 3 tires here that are all the same labeled size, but are all completely different as far as actual size because they are all different brands.
#27
5 on 4.5 is a ford pattern, mustang, ranger, most mid size fords. Just FYI!!!!!
disabled/desert shield/storm vet, proud to have served! 582, 1782, 124 (x2), 154 LO-BOY, |
#28
Thanks everyone. I was looking at something else when I typed that in. Brainfart mostly. Matt G is right too... I just did perfect world numbers to see if the system I wanted was possible. It should still work with the correct tire diameters put in from that start. I was bored at work one day and this is the result.
#29
Articulated 4 WD Cub Cadet
Cub I have been working on. Used two case transmissons to power the front and back wheels. The articulation joint is a combination of two front car hubs and bearings. I have different tires to make all the tires match. Just waiting for some snow to try it out. If everything works OK this winter, I will take it apart next summer for a paint job.
#30
Thanks for the progress pics!
