Old 07-11-2020, 07:20 PM
dennwaf dennwaf is offline
Got the tractor split. Drained the oil from the transmission. Trying to remove the brake arms and shaft from reduction housing. Brake shaft is really stiff, won't hardly turn. The pins in the arms are really stubborn. I wedged a piece of 1x2 between the axle housing and brake lever near the pin for backing. The first pin's end shattered when I used the roll pin punch on it. Tried the other arm's pin and got it flush with the casting and it won't go any further. Bent one of my cheap Chinese punches beating on it. Is the drill next?
Denny
Old 07-11-2020, 08:06 PM
Dart1917 Dart1917 is offline
The pins are hard, you wont be able to drill them. It's probably mushroomed on the end. Drive it back a little and grind the end off and try again.
Old 07-11-2020, 10:36 PM
I put some heat around it got a BF hammer and BF punch, 3/4 in pipe against a concrete wall for backing and took some BF swings and it's out. 2 hours. Am I all wet or is a 1/4 in. coil pin overkill on a brake lever? I wished it would have been in my drive line coupler rather than the skinny roll pin that started all this. But I'm having fun getting acquainted with every nut, bolt and PIN on my girl.
