#21
149 oil pan gasket
Thanks for all the advise. I will take the pan back off and start over. Don't know why it leaked. Used only the gasket the first time. No sealer. It leaked around gasket on one side. When I rebuilt the engine I trued the cast iron oil pan with glass and sand paper. Looked pretty good after that. I really don't want to pull that engine again. I have another oil pan gasket. Bought 2 the last time. Never heard of a thread chaser. Hope the threads are ok. Will be next week before I can work on it. Thanks once again and have a great day.
Bob |
#22
#23
Here is a picture of some thread restorers "chasers" notice the tip does not come to a point. This allows you to get to the bottom of the threads without the tool bottoming out. You can most likely get just one "the size you need" at a hardware store. A cheap set can be found online. I would not buy an expensive set if your not using them very often
#24
Jeff 62 O, 1641, 1864, 1862, 1535, LT1045 #4 cart |
#25
149 oil pan
Could some one verify that the oil pan bolts are 1 1/2" length. I put them in block with out oil pan and the distance left on bolt seemed too long to tighten pan down. Looked like they would bottom out before tightening oil pan. Thanks in advance and have a great day.
Bob |
#26
#27
1" bolts are for mounting to the frame.
The pan bolts are indented head and also 1" long The parts book tells you all this guys! |
#28
149 oil pan
finsruskw, Where might one find a parts book for the Kohler 321A? I have looked in the Technical library- Tractors but could not find what I was looking for. Help appreciated. Have a great day.
Bob |
#29
Mr. Bob, try this link....
scroll down and click on K321.... oil pans, etc. page 69/70 (bolts described, not illustrated) https://www.kohler-engine-parts.opee...ducts_id=12023 |
#30
I always go here
https://www.cubcadet.com/en_US/conte...rtstream.html# Has all the tractors broken down by sections. Click on the 2nd cub cadet, not the newer MTD version on top. I also have the hard paper copies as well |
