#21
Had to do this in 3 posts
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
#22
Final post. For now.
#23
Looking good!
#24
#25
looks awesome.
Donovan: 62' Original-fenders 63' 100R-K-321a,lights,creeper,electric lift 149-original paint, tiller, three point, duals, ags 1811Custom -M18-18hp kohler magnum, power steering and hydraulic lift with Three point and sleeve hitch. ---------------------------------------------------- Attachments:three-QA 42inch,42inch blade,one-38inch cast end, QA 44inch deck Brinly 12inch plow, 2x cultivators and x2disc Brinly Tool bar cub10: |
#26
Been a long time coming....
I know it's been a while since I put my progress on here for my hydraulic expansion of the 784. In the meantime, I have found many ways to fail. Tonight, I figured out how it was going to work and got everything lined out.
The first pic is of the mess that is the hydraulic hoses - this was a real challenge because this all has to fit behind the gas tank. No pics yet, but it fits like a charm. I have yet to get the wiring harness behind the steering column - this will clean it up a lot. There seems to be ample room behind the valve bank and I think it will work out well. Also, it's almost impossible to see, but the valve on the far left side of the picture has float capabilities. This will allow my mower deck to float and will also all sleeve hitch attachments to float or use down pressure on command. No slotted metal bars to chains. All of the tabs that control the valves can slide back and forth pretty easily. The levers are lined up so that when the tabs are lined up, everything is kosher. I had to bend one of the hydraulic levers so that my weld on the center lever wouldn't interfere. Worked out pretty slick. Still have to get the links put back together, but that will come in time. I need to slap a coat of paint on the levers, but I had enough of the rubber grips off of the old levers that I put them on just to see what they would look like. I am getting pretty excited to see everything put together and not leaking. My pictures do not show where I ran my hoses. I ran the hoses along the left hand side of the frame - there was nothing ran there and the 4 hoses fit perfectly between the trunion linkage and the frame. I used a zip tie to keep the hoses out of the fan. The back end, where the female couplers will mount, is not finished. I am planning on taking a piece of metal and bolting it between the frame and the transaxle. I want to keep all of the hoses on the inside to protect them as much as possible. Let me know if you have any questions or comments - glad to hear suggestions! Nate
#27
Nate one word impressive!
#28
#29
Looks great! Now you have me thinking about doing about the same thing to my 1812! hmmm
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
#30
Stuebenville - that's just a stone's throw from me! I haven't seen too many people that live reasonably close.
