Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines
Old 11-24-2014, 06:13 PM
IH_147's Avatar
IH_147 IH_147 is offline
you can wiggle it up and down quite abit
100,122,126, 126, 126, 147,147,800,127, 982, 1210, farmall 300, farmall 560 diesel
Old 11-24-2014, 06:23 PM
Up and down is normal.
Old 11-24-2014, 06:47 PM
IH_147's Avatar
i know alittle bit up and down is good but this isnt like that and i know its sucking air because i sprayed carb cleaner on the spot that is sucking and it took it hard and stalled and did it a few more times and thats were its sucking
Old 11-24-2014, 07:14 PM
Well if there is a lot of up and down, that would mean the butterfly is worn out. You wouldn't be able to idle it down if that is the case. I'm not saying your throttle shaft or bore isn't loose..... but there is no seal on the throttle shaft. I always add a felt seal to it when I rebuild if I can. I'd venture to say that if you spray carb cleaner at most carbs at the shaft it would cause a stumble. Go ahead and put a shaft bushing on it, as it's a good thing to do. It may fix it. I'm not convinced just yet as I can't see it. If that doesn't fix it I'm sure you will let us know.
You know where to get a bushing right?
http://www.onlycubcadets.net/forum/s...ad.php?t=10329
Old 11-24-2014, 07:30 PM
IH_147's Avatar
great imformation jonathon you will be the first to know if this doesnt work
Old 11-28-2014, 11:38 AM
IH_147's Avatar
well Jonathon the bushing did the trick and she runs like a champ now thanks for all the help
Old 11-28-2014, 11:50 AM
Good deal!! Now, put that thing to work!!
