Old 06-17-2014, 01:03 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
To the best of my knowledge IH never used wheels that had the valve stem on the "inside" (front OR rear wheels).
Narrow Frame tractors with wide wheels have the deep dish side of the wheel pointing outward with the valve stem on the outward side (deep dish side) Wide Frame tractors have the shallow side of the wheel pointing outward with the valve stem on the outward side (shallow dish side).
If your valve stems are on the wrong side of the wheel then you have the wrong wheel on your machine.
If you have narrow front wheels with the valve stem on the inside... Take the wheel off and turn it around.
Thanks for clearing that up Mark!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 06-17-2014, 01:33 PM
dgrapes59 dgrapes59 is offline
That was the thinking behind my initial reply and had narrow rims on my mind.
David
Old 06-17-2014, 10:28 PM
jcsmith jcsmith is offline
dgrapes59, I did just that on my dual setup, Sears Suburban wheel inside, Cub outside. Makes it easy to check pressure.
Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 06-18-2014, 08:45 AM
OffTime's Avatar
OffTime OffTime is offline
JD wheel offset is different on all models that I am familiar with. Wheel Horse uses a very similar offset to Cub Cadet and have the stems on the inside. David-Bradley / Sears also uses a similar offset. I suggest it is one of these two.
Matthew B
1972 129 w/hydraulic lift and head light option soon to be repainted
Old 06-18-2014, 10:49 PM
340demon's Avatar
340demon 340demon is offline
Default Rims
Sorry it took so long for the pictures, here's 3.
Unless someone can give me some information, I have no way to tell if they're John Deere / Sears / or Other.
I do like the dual wheel idea with the stems on the inside and outside.
I appreciate all the info!
Sam
My Cubs
108 & 1250 & 104
Tiller, snow thrower,
Plow
Old 09-04-2014, 11:05 PM
chris hall's Avatar
chris hall chris hall is offline
all my wheel horses have had the valve stem on the inside of the wheel.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
