Old 01-20-2019, 08:13 AM
twoton twoton is offline
Originally Posted by russlavoie23 View Post
Tried posting pictures of the tractor but no luck
https://www.onlycubcadets.net/forum/...=6213#post6213
If this does not work your pictures may be to large and will need to be resized.
It seized on me, I got it free but now it cranks with no start and weak compression. I was turning it over the again trying to start it and it just seized again but ended up freeing it up again. I wouldn't be opposed to having this one rebuilt as it made great power and ran excellent when it was going. Motor seized all of a sudden no typical warnings.
Just wondering on this “It seized up on me” and “I got if free”.
What was going on when it seized up? Were you working the tractor? Was it warmed up, hot?, just trying to start it? What…
And how did you free it up?.. several times. What did you do to accomplish this???
Thanks guys!
Currently I can't get the motor to fire, it's getting fuel and spark but it won't fire, even on starting fluid or a little gas under the plug. Also when I was trying to get it to fire the motor had locked up on my but I was able to free it up. Seems like low compression as well. The motor just got a tune up as well so it has fresh oil, plug, clean carb ect.
How do you know it’s getting spark? What makes you think it has low compression? Did you do the tune up? What oil? With the temps we been having lately it should be 10w30. What spark plug? Gapped correctly? Should be Champion H-10C or equivalent gapped to .035 inches.
What was done to clean the carb? Is the rest of the fuel system clean? Spraying carb cleaner in the intake is not cleaning the carb. You may need to remove, disassemble and rebuild the carb properly;
How to rebuild the carb;
http://mgonitzke.net16.net/tools/carb_rebuild.pdf
carb rebuild kit (part # 25 757 02-S)
What kind of condition is the starting circuit in? Does it crank over strong before it “seized”? A weak battery, corroded start circuit, worn out starter will not be able to spin that engine over well enough to fire it off. It will start to turn over, kinda weeze and then stop. Your battery should test 12.6 volts at rest. Not immediately after being charged, but after sitting overnight. You can then do a voltage drop test to isolate issues in you starting circuit;
https://www.youtube.com/watch?v=paw8...a1WqUHuGt-UsNV
and here’s another worth watching;
https://www.youtube.com/watch?v=LGB6...a1WqUHuGt-UsNV
Like others have said, did you check the timing?
How to set the timing using the static method;
http://mgonitzke.net16.net/tools/static_timing.pdf
If you need a new set of points;
Points Kohler (part # 47 150 03-S)
Verify that the valves are moving freely?
I know that the engine is new to you but do you know if the head has ever been decarboned?
How to de carbon the head, piston top, valves and lifter galley;
http://www.onlycubcadets.net/forum/s...223#post338223
head gasket, stock, 10 - 14 HP (part # KH-47-041-15-S)
And how to plane the head;
http://www.onlycubcadets.net/forum/s...95&postcount=1
I would be very curious about the start circuit…
Old 01-20-2019, 12:24 PM
RLause's Avatar
RLause RLause is offline
Very good write up
Richard
Old 01-20-2019, 12:29 PM
Gompers Gompers is offline
Popping the head off will tell you a whole lot about the condition of the engine. You can see if the cylinder walls are scored, if the piston is super loose, if there's a ton of carbon built up, how the valves look, etc.
If you're convinced it's got serious mechanical issues, that doesn't take much time and is pretty easy to do.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240
Old 01-21-2019, 11:47 AM
Here is a re-power kit for the 1650 from Small Engine Warehouse
http://www.smallenginewarehouse.com/...tegory=1709551
Old 01-21-2019, 12:14 PM
I think that's the kit Mr Zippel used in one of his projects.
Wasn't there some issue related to the PTO?
Old 01-21-2019, 01:48 PM
Zippy just had a worn out PTO that he ended up changing to one from Xtreme
Old 01-21-2019, 02:13 PM
Oh, OK. Thanks Sam.
Old 01-26-2019, 09:52 PM
russlavoie23 russlavoie23 is offline
Thanks for the reply guys, I was able to hunt down a 16 for the mower and am just going to do a swap seeing the 16 is what belongs in it. Maybe I'll give it a go at tearing down the 12 in it now.
Old 03-10-2019, 04:16 PM
Just an update on the rebuild, motor is almost done
Old 03-10-2019, 04:19 PM
Pictures of the 1650
