#21
I bought a scan tool that you can see the coolant temp. My 1998 Chevy was not acting right. It helped me figure out what was wrong and lets me see the temp the ECU is seeing from the sensor.
#22
I always replace a t-stat if I change a water pump. Just as a note, there are two different sensors. One for the gauge, and one for the ECM. Just because one reads, doesn't mean the other one does. |
#23
Edit: so there's two temp sensors, I get that. Without buying a reader is there a way to verify engine temp? Such as taking an infared thermo and gathering readings from the block? Could a failing lower hose collapsing cause this issue as well? Btw thank you for taking the time (and patience) to read through this and help out, I appreciate it.
-Ryan
#24
You don't quite understand, or I didn't explain well. Don't check for air with it running. Top the level off in the reservoir, then leave the cap off, take the clamp off of the highest heater core line, and I usually just grab the hose with a pair of pliers and twist it to break the seal. (Be careful not to damage the hose.) Then once it's loose, stick a flat blade screwdriver into the end between the hose and the pipe. Just enough to let out air/coolant. If coolant comes out, then it's fine. Put the clamp back on. Then, IIRC, there is a small hose running from the top of the radiator back to the coolant tank. Pull it off and check to see if it has coolant at it. Should be a small,,,, maybe 1/4" hose. (Can't remember) On most models of anything really, if the t-stat sticks closed and the engine is super hot, yes. You should have scalding heat. If it is stuck open, or opening too soon and not getting to operating temp, you will not get hot air out of the heater. The fact you have cool air is a good indication that the water pump isn't moving coolant, either because it is air locked, or the pump is bad. |
#25
This is the best advice/ description of a real problem I've read. I have dealt with this very issue so many times. Every summer, when it gets really good and hot, we always had a huge rash of overheating cars/trucks. Primary cause: Exactly what George says. Plugged up exterior cooling system. Sometime literally the area between the A/C condenser and the radiator was completely full. We always just pulled the vehicle into the wash bay, drained the system and removed the radiator completely. Power washed it, and the A/C condenser. Sometimes if it was an easy removal, we also removed the condenser. Completely cleaned them, went ahead and back flushed the cooling (internal) system with water with the t-stat removed, then refilled it with new coolant. That may sound like a lot of work, but we had a set price for the actual cleaning. So you paid the same labor as a radiator R/R, but the bill was far less than the cost of a radiator. Obviously, if it needed a hose or something we would take care of that while out..... but back to the original statement: It is VERY true that a lot of vehicles cooling systems are plugged up with road debris, and bugs. Good post George! You're welcome Ryan. |
#26
I'm wondering if once the truck get to operating temp and the thermostat opens allowing a fresh batch of coolant into the engine, it's sucking air from somewhere therefore shoving air rather than coolant into the engine causing the spike. At this point, I'm pretty convinced the pump is good as well as the thermostat but I have the "simple" problem of air trapped in the system somewhere. Does this theory sound logical to you guys? Any good ways to burp the system?
-Ryan
#27
Just take the cap off and fill it with it running. If you got the air out of the water pump, then it will self bleed from there.
Now, the question is, where did the coolant go? I bet the water pump is leaking..... |
#28
#29
Post #4. Adam talked about changing the intake on his 350 and said it air locked. He was saying that because Ryan changed his intake. The intake on a 350 has water jackets in it. The 5.3L motor has a dry intake. Don't even have to drain the coolant to remove it. So, in essence "comparing" the two jobs/motors.... yet they are worlds different.
#30
Then in a few weeks (if tonight takes care of it) I'm going to do a flush on the cooling system since I will have added water throwing the ratio off.
-Ryan
