#21
im new to this sorry if im having a hard time explaing whats going on yes i have spark and now that i think i poured to much gas in it ill try in the morning
#22
He said he had spark in three different posts. I guess it's easy to miss if you're talking instead of listening.
Little hard to ferret out because of no punctuation. I'll let the one man, five piece band contribute now. |
#23
Ok, how do you know you have spark? Did you use a spark tester or did you pull the plug and touch it to the head? How did the spark look? Was it nice and bright or was it weak?
#24
i tested the spark with a inline spark tester
#25
Ok, did you test both cylinders?
#26
yes both have spark
#27
ok, since it has a magneto we can rule out timing unless the key sheared on the flywheel but there's a few step to take before we go there. id pull the carb and take the bowl off to see if its full of crud, id use carb cleaner and compressed air to blow through the passages to ensure its not plugged and then put it back on.
#28
Yeah, I'm sure Tim read where he said he has spark, but like me, he wants to make sure he tested right. You can have spark, but that doesn't mean it's good spark. You know that, I'm sure. I think Tim is doing a fine job! Not sure why you are making snide comments about him being a one man, five piece band. |
#29
#30
Oh. Huh. He never quoted me.... You sure?
Well, either way Tim, I think your doing a fine job. Carry on! |
