#21
OK now if you decide to go for a Kohler CH it is also all factory bolt in. You'll need a CH18-22+ hp, you'll need a motor plate, engine spacers, muffler, heat shield, battery tray, fire wall and a drive shaft from a 2084 or a 2284. This was an 1882 that pitched a rod so I repowered it with a CH22 all factory parts.
You should be able to get good used parts from Patton Acres, & Cub Classics.
#22
One last set of pics. 1st is a D640 out of a 1782 2nd is a WG600 out of a 2182. Motor mount is off the WG600 but it is the same as the one for the D640
#23
The replacement motor is a WG600 B. One of the main difference distance between the 2 engines is the crank to water pump distance. The fan on the water pump hits the crank shaft pulley with the WG600 B. Is the Kohler engine a magneto or a battery ignition system? The 2182 is battery ignition. May have to rewire the 2182 to run the Kohler engine. Quote:
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
#24
Post a pic of the WG600B. I want to see the water pump. My guess is that you can swap water pumps.
The CH is a mag ignition. You'll need to do some wiring. I'm moving this thread to the CCC/MTD section it has gone way past a wanted ad.
#25
If you want a copy of the service manual for the Cyclops series or the Kubota WG600 you can join Cub Cadet Cyclops on Face Book. https://www.facebook.com/groups/666265203510023/
I uploaded both manuals a few days ago. It got to be a PITA me having to e-mail them every time someone wanted them.
#26
http://www.cubcadet.com/webapp/wcs/s...0-A/0040300042 Click on the link and it will take to Cub Cadet Parts lookup.
#27
Converting the wiring from the 12v ignition on the Kubota engine to mag ignition on a CH could be done with a relay. Myself and others have done this when installing a Mag 18 or 20 engine in 782, 982, etc.
Sounds like the tractor is worth saving as its loaded up with nice options. I love way the WG600 runs. So smooth and quiet. |
#28
#29
Cub Cadet made an odd ball tractor when they design the 2182.
#30
Picture of the Kubota gas engine in the 782
2182051.jpg Side view-radiator support 2182060.jpg Left front corner view 2182059.jpg View of the water pump 2182058.jpg Valve cover with ID logo on it 2182061.jpg The 2182 is at the owner's place until we find an engine.
