Greg Rozar AKA- CubDieselFan
Old 04-05-2012, 12:31 AM
You make this look to easy! Great job!
Old 04-05-2012, 11:48 AM
Awesome work! You did an excellent job.
Old 04-05-2012, 09:51 PM
jlampe94's Avatar
jlampe94 jlampe94 is offline
Thanks guys. still has a way to go. Talking to a guy up the road about it and found out he has a dual spool valve off a 982 he'll sell me if he finds it.lol Then i can run some outlets to the rear for my 3pt blade i made and cylinders on any future projects. Looking at the exhaust, wondering if anyone has ran a stack out the hood on a quietline before? Any pics you may have would be appreciated. Also found out how the light panel on these was made and looking i think i can make my own with some lights i have thatl look about like stock. Been looking at my pto switch (since im not putting a pto on it) for other uses and thinking making it to run a 3pt sprayer in the future since its already there.
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4.
Old 04-07-2012, 08:42 PM
jlampe94's Avatar
We gotten some done to the 1200. Did some wet sandind with 2000 grit and buffed it out i think its looking pretty decent for being original. Also painted the wheels, axle extensions, front top grill and feet pads just to help. Dropped the motor in to make sure my plate i welded in was right and everything lines up good. Hydraulics also came in today and got the cylinder on it. Have a lead on a dual spool valve so waiting to put one in until i find the price on that. Been looking at what to do for exhaust and finally decided to run a muffler up through the hood painted black. IH#2 from tsc i think it was. Any ideas you may have that would make it better let me know!
Old 04-07-2012, 10:07 PM
Thanks for the update and pics.
Old 04-09-2012, 11:05 PM
jlampe94's Avatar
Picked up a dual spool valve and the handles off a 82 series tonight. Also got the motor cleaned up and put back together for the most part, waiting on a carb kit and for the breather im going to weld a fitting on and run it up to the grill with a filter on the end to keep the engine cleaner. Does anyone know why on the return line end of the valve there would be a T on it? And how come the fittings coming out of the valve for the cylinder and outlets are really small instead of the 1/4" like whats on a single spool? Also a pic of the 10hp my dads rebuilding for a 104 were in the middle of restoring.
Old 04-10-2012, 10:16 AM
Thanks for the pics. I'm looking forward to this.
Old 04-10-2012, 10:54 PM
jlampe94's Avatar
Got the valve in the 1200 tonight and levers out of an 82 series with a lil fab. Need to get another dash tin to cut a hole in for em since the one thats on there is in very good condition, otherwise there done. Now for the lines and need to make the new breather cover and she'll be running
Old 04-10-2012, 11:10 PM
Cool pics! Thanks for updating us.
Old 04-12-2012, 10:20 PM
jlampe94's Avatar
Didnt get quite as much done as i was hoping tonight, had to make a run for some parts and work on the truck a lil. But i did get a different dash tin to cut a hole in and got the dash mounted back together and a new choke cable in. Also finally got the new axle pin and 2 bushings (had 1 before and homemade pin for time being) and WOW barely any slop in the steering now Thats my new breather filter i think im going to locate up in the front grill.
