#21
MattG. Great! Thanks again. Now I can start to collect my parts.
MH - I fabricate everything I can. But some things I'd rather get factory. The 3 pt hitch, factory. The sleeve hitch adapter, I may make from scratch. Thanks again. :biggrin2.gif: |
#22
Taking another look at my 122 raises yet another set of questions. First, has anyone actually seen a 122 plow? I haven't seen a picture or heard anyone talk about plowing dirt with a 122. Second, there's a plate that goes between and is bolted to the fenders. It appears that this plate needs to come off to mount the 3 pt hitch. Do the fenders rely on this plate for support?
#23
You might have to remove that plate to mount the hitch, but you can put it back on again after it's mounted. There's a cutout in it for the hitch to fit through.
Your 122 will plow just fine. Just because few people plow at a plow day with one doesn't mean that it won't work... |
#24
Thank you once again, Matt. I can't see the entire plate since my weight bucket is on. I'm finding the hitch and adapter and plow all in the price range I want to spend. I just want to be sure before I drop a few hundred bucks. Then I'll have to wait all winter before I can try it all out.
#25
First Cub I plowed with was a 122. Good plowing tractor if they are set up right.
#26
I'm certainly looking forward to plowing. My cousin is a third generation dairy farmer, and I've done a lot with full size farm tractors. It should be a real blast to plow with the cub.
