#21
Why Farm Half When You Can Farmall? 1282 | 44C Deck, Chains, 42" Blade, Cast Weights, 020" Over K301 * 1711 | 50C Deck, #1 Rear Rototiller w/ Extensions, Sleeve Hitch, KT17S Series II 24302 --> CH18S * 1811 | 46 GT Deck, 42" Blade, Chains, M18 Magnum, Sleeve Hitch * 1782 | 60" #375 Deck, Kubota D640 Diesel * 1862 | #450 Snowblower, M18 Magnum * 782 | Y/W KT17 Series II, Sleeve Hitch * 984 | Y/W Onan/Linamar 20HP, Sims Cab, CAT 0 3 PT w/ Rear PTO, 60" #374 Deck |
#22
This modification looks great. I just picked up one of these too. Do you have any additional information/tips for modification to add this clutch set up?
#23
I pretty much explained the mods that were required. Notching the frame allows the clutch to be removed and the belt to be changed without removing the engine. Cutting a hole in the side shielding is required to clear the end of the clutch. I used a long straight edge to align the clutch sheaves. (actually an old chainsaw bar...lol). The secondary clutch was near the end of the shaft but the shaft still had enough meat to grab the end of shaft support bracket. I think the only improvement with the clutch would be to go with heavier weights in the primary clutch to engage the drive at a lower RPM. Feel free to email me at allyolds68@icloud.com if you have any other questions. I know these machines pretty well. I also have a spare axle shaft for sale if anyone needs one. I broke an axle a couple years ago and had two shafts made as both sides were identical and were no longer available anywhere. Heald Haulers and Pugs are almost identical. I think Cub Cadet bought out Heald Hauler to build these |
