Old 08-10-2013, 10:26 PM
johncub7172's Avatar
Now the holes are close, I can get the pivot pin installed.
I wanted to have another final look at the spiral pin. I was looking for any cracks in this harden metal. There was wear, but not what I thought was excessive, and looked very cylindrical end to end, and straightness was true.
Old 08-10-2013, 10:35 PM
In order for me to get a straight hit on the punch, I needed to first release the bail on the implement lift lever, as I have spring assist and needed the push/dozer blade lift rod removed.
Small, light hits on the punch were many. I feared to crack the spiral pin and was extra careful. Tap- tap- tap and the spiral pin was seated flush, as when I removed it.
Next was to grease the newly seated axel.
Old 08-10-2013, 10:39 PM
Another look see under the tractor. The axel is installed and greased.
The axel now sits in a horizontal position, something I never seen before.
Old 08-10-2013, 10:45 PM
Thumbs up
I cleaned all the components, and hardware. I used high temp grease to re-assemble the steering unit.
Here is the IH Cub Cadet, all back together again. Any forward/backward axel movement is now eliminated. No clunk-clunk left turn/right turn noise coming from the front of the tractor. After the snow season, we'll see if the gap has opened any.
Old 08-10-2013, 10:47 PM
The 71 is looking good, John!
Old 08-10-2013, 10:49 PM
Nice work
Old 08-11-2013, 12:19 AM
good job!!
Old 08-11-2013, 09:06 AM
jbrewer's Avatar
jbrewer jbrewer is offline
Very nice job. All that work should ensure that it doesn't snow this winter! :-)
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-11-2013, 09:41 AM
Originally Posted by cubfixer View Post
Nice pics and interesting thread!
Thank you! I did put a little thought into the project as a whole. What I wanted to also add to the thread, is to install the pivot pin's spiral keeper pin the same way you removed it. Meaning the end you use to punch out the spiral pin , install that end into the c-channel bushing first. My ideas about this are suggestive only, it worked!
Old 08-11-2013, 09:43 AM
good job
