Old 11-29-2017, 07:03 PM
Thought I remember someone did a block heater that goes in the freeze out plug in the flywheel end of the engine.
They did. See post 15. Stan put the link to the thread.
Old 11-29-2017, 08:17 PM
jbrewer's Avatar
jbrewer jbrewer is offline
When I go work on mine to replace the fan and the spirol pin, I'll look but IIRC mine is at the flywheel end of the engine.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-29-2017, 08:27 PM
Rocking416's Avatar
Rocking416 Rocking416 is offline
Thank you for all the good ideas. I think i am going to go with GR Starter and glow plug upgrade. I know i seen the link for the glow plug upgrade with starter solenoid. I need to find it. Currently the tractor is torn apart. I went ahead and ordered the PTO Clutch from Xtreame
My biggest dilemma is I do not live where the tractor is stored.
Defiantly makes repairs slow.
I will keep everyone updated with progress
Old 11-29-2017, 08:29 PM
Rocking416's Avatar
I figured i would post a few pictures of it.
I hope to one day wax the original paint and have the wheels painted and replace the tires
Old 11-29-2017, 08:55 PM
DieselDoctor's Avatar
Remember that the D600's flywheel is at the radiator/front of the engine bay. The driveshaft comes off of the front crank pulley so rotation is correct.
Old 11-30-2017, 06:55 AM
j knight j knight is offline
Default Battery for the 782D
A really good battery for the 782D is the Odysey Battery.
Contact them and they have one that fits and is a good cc amperage.
Just measure the width height and height of the battery tray.
Joe
Old 11-30-2017, 01:27 PM
Got a part number for that Odysey battery?
Old 11-30-2017, 05:42 PM
Default odysey battery
Just call and give him the size of the battery tray and the height from the
trey to the bottom of the black plastic lip of the dash panel. All in all it has
to fit under there.
they are listed by size and the position of the + AND - terminals.
Tell them what tractor you are trying to put it in.
I did have the information on a hard disc that cleaned.
They are not cheap but the cc and they will outlast at least two
other batteries.
Was going to go that route but put in a block heater in the front of the head. If you do this one see jeff for a new
support for the fan jack. As it needs to have a hole in it for the heater. Newer glow plugs and a torque starter
last year used the heater three times. But it needed to be on for at least two hours.
Old 11-30-2017, 06:31 PM
jbrewer's Avatar
Very nice tractor you have there by the way!!!
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 11-30-2017, 09:27 PM
Here's the link for the gear reduction starter. It lives in our technical library.
http://onlycubcadets.net/forum/showthread.php?t=1
